NBAR config
rehan_uet
In NBAR configuration if i have to classify all the traffic with ".jpeg" extension from "any.com"; would following configuration work or is there any alternative to it
class-map xxx
match protocol http url ".jpeg"
match protocol host "any.com"
and then use this class-map into a policy-map for further action.
casanavep
Level 3
Level 3
Should if the class-map is a "match-all" type which would force both conditions to be true.
Marwan ALshawi
Make it like
"*.jpg"
"*.com"
