Showing results forĀ
Search instead forĀ
Did you mean:Ā
nbm flow-definition ingress interface
Tom22
Is it possible to specify the ingress interface when creating a static flow with the "nbm flow-definition" CLI command?
There are two interfaces on which the multicast traffic can come in. For some reason the "nbm flow-definition" command seems to automatically select the wrong one (Src-Intf column in 'show nbm flows'), not the one on which the data is coming in.
It seems to be possible via the NX API (see below), but can it also be configured via the CLI?
{"nbmConfFlow": { "attributes":
{"group": "237.1.1.1", "source": "10.101.13.2",
 "IngressIf" : "eth1/4",
 "bwKbps" : "300000", "policed": "ENABLED"},
        "children": [
         { "nbmConfFlowIf": { "attributes": { "id": "vlan100" } } }
0 Replies 0
