12-17-2025 12:21 PM
Greetings
I have a N540-24Z8Q2C-M and start receiving log message from OBFL flash
0/RP0/ADMIN0:Dec 17 14:12:57.777 AST: mediasvr[2623]: %MEDIASVR-MEDIASVR-4-OBFL_FLASH_ACCESS_FAILED : OBFL flash access failed, error : Read-only file system
0/RP0/ADMIN0:Dec 17 14:12:57.795 AST: mediasvr[2623]: %MEDIASVR-MEDIASVR-4-KERN_OBFL_MSG1 : obfl, kern msg : Kernel UBIFS error message in kernel log, check obfl flash.
0/RP0/ADMIN0:Dec 17 16:17:04.711 AST: obfl_mgr[2626]: %INFRA-OBFL_MGR_COMMON-3-OBFL_DEV_ERROR : OBFL device access error : -904919038 [OBFL no str version for this error ]
I read this article https://community.cisco.com/t5/tkb-サービスプロバイダ-ドキュメント/ncs5500-mediasvr-mediasvr-4-obfl-flash-access-failed/ta-p/4171382 But notice that the steps are for ncs5500. Its there a documentation for the NCS540 to fix this?
I will appreciate any information that you can provide.
Solved! Go to Solution.
12-19-2025 06:14 AM
I manage to follow the fix that I post for the NCS 5500 and it works for the NCS 540. Here are the steps
prior confirmation
sysadmin-vm:0_RP0# run
[sysadmin-vm:0_RP0:~]$mount | grep plug
/dev/ubi3_0 on /mnt/plog type ubifs (ro, relatime) <<<<< Before performing the procedure, reconfirm that the target FS is ro
[sysadmin-vm:0_RP0:~]$ls -l /mnt/plog
---snip---
formatting instructions:
[sysadmin-vm:0_RP0:~]$umount /mnt/plog/[sysadmin-vm:0_RP0:~]$mount | grep plug
[sysadmin-vm:0_RP0:~]$arp
---snip---
[sysadmin-vm:0_RP0:~]$ssh 10.0.2.16 <<< Connect to host OS
[host:0_RP0:~]$ ubidetach -m 3
[host:0_RP0:~]$ ubiformat /dev/mtd3 <<< It takes about a few minutes
ubiformat: mtd3 (nor), size 18874368 bytes (18.0 MiB), 144 eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 1 bytes
libscan: scanning eraseblock 0 -- 0 % complete
libscan: scanning eraseblock 1 -- 1 % complete
libscan: scanning eraseblock 2 -- 2 % complete
---snip---
ubiformat: formatting eraseblock 143 -- 100% complete
[host:0_RP0:~]$
[host:0_RP0:~]$ ubiattach -m 3 -d 3
UBI device number 3, total 144 LEBs (18855936 bytes, 18.0 MiB), available 140 LEBs (18332160 bytes, 17.5 MiB), LEB size 130944 bytes (127.9 KiB)
[host:0_RP0:~]$ ubimkvol /dev/ubi3 -N plug -m
Set volume size to 18332160
Volume ID 0, size 140 LEBs (18332160 bytes, 17.5 MiB), LEB size 130944 bytes (127.9 KiB), dynamic, name "plog", alignment 1
[host:0_RP0:~]$ exit <<< Return to guest OS shell of sysadmin VM
---snip---
Connection to 10.0.2.16 closed.
[sysadmin-vm:0_RP0:~]$mount /dev/ubi3_0 /mnt/plog -t ubifs
Confirm that /dev/ubi3_0 on /mnt/plog type ubifs (rw, relatime) <<<< rw
Total 0
restart obfl_mgr process
show processes all loc 0/RP0 | inc obfl
process restart obfl_mgr location 0/RP0
run ls -l /mnt/plog/
Check if syslog output stops after watching for more than 10 minutes
XR VM:
Show logging
12-18-2025 04:49 PM
Most probably you're encountering a known issue, see your options here:
https://www.cisco.com/c/en/us/support/docs/field-notices/721/fn72107.html
Cristian.
12-19-2025 06:07 AM
That issue is for SSD harddrive and that only affect firmware up to 7.3.x. I'm in 7.4.2 that is already fixed.
Thanks for the information.
12-18-2025 09:34 PM
Hello
possibly a bug - try checking your software for any related SMUs pertaining to this issue or upgrade
12-19-2025 06:14 AM
prior confirmation
---snip---
---snip---
---snip---
[host:0_RP0:~]$
---snip---
Total 0
XR VM:
Show logging
