NCS5002 MPLS license
omera
Hey guys,
I was looking at Cisco’s licenses for the NCS5k and it's kinda confusing the NSC has a license for IP/MPLS which is XR-NC50-PK9-06.05 (Cisco IOS XR IP/MPLS Core Software 3DES), another two licenses for L2 and L3 VPN features could anyone tell me the correlation here? do I need the two VPN licenses to use VPLS and L3 MPLS or I can go by with XR-NC50-PK9-06.05
Thanks.
according to Table 6 in the attached document, there is only the P and the PK9 license. Where do you see the other two licenses you are mentioning ?
Either way, I think the PK9 license includes all features...
https://www.cisco.com/c/en/us/products/collateral/routers/network-convergence-system-5500-series/datasheet-c78-741081.html
In the link below you'll find the software license that I've posted earlier, and also if you log in to CCW and create an estimate for the NCS you'll get the following license as an option.
https://people.ucsc.edu/~warner/Bufs/cisco-ncs5001-datasheet.pdf
also this one
https://www.cisco.com/c/en/us/products/collateral/routers/network-convergence-system-5000-series/bulletin-c25-734310.html
