Need BGP Update-Groups explanation
rlortiz
We are confused by the output of the show ip bpg commands on a 12.0(29)S router and other IOS version routers like a 12.1(22)E1 router. (I have removed most of the ip addresses for security reasons)
router1#sh ip bgp xx.xx.xx.xx
BGP routing table entry for xx.xx.xx.xx/32, version 465794
Paths: (2 available, best #1)
Advertised to update-groups:
1 2 3 4 5 6 7
14496
xx.xx.xx.xx from xx.xx.xx.xx (192.25.199.9)
Origin IGP, metric 5, localpref 120, valid, external, best
Community: 9827:120
14496
xx.xx.xx.xx (metric 510) from 192.46.77.190 (192.46.77.190)
Origin IGP, metric 5, localpref 120, valid, internal
Community: 9827:120
IOS (tm) RSP Software (RSP-PV-M), Version 12.0(29)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 04-Aug-04 16:01 by kellmill
Image text-base: 0x400110A8, data-base: 0x41430000
What is this notation ( 1 - 7 ) of update-groups and how to read it ?
As compared to a similar command on router2:
router2#sh ip bgp xx.xx.xx.xx
BGP routing table entry for 192.46.77.1/32, version 3788128
Paths: (2 available, best #1, table Default-IP-Routing-Table)
Advertised to peer-groups:
BB->Site HRR->client-lite HRR->EAR
Advertised to non peer-group peers:
xx.xx.xx.xx xx.xx.xx.xx
9827
xx.xx.xx.xx (metric 400) from 192.25.199.9 (192.25.199.9)
Origin IGP, metric 5, localpref 120, valid, internal, best
Community: 14496:120
9827
xx.xx.xx.xx from xx.xx.xx.xx (192.46.77.190)
Origin IGP, metric 320, localpref 120, valid, external
router2#sh hard
IOS (tm) c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(22)E1, EARLY DEPLOYM
ENT RELEASE SOFTWARE (fc1)
Compiled Sat 17-Apr-04 07:01 by pwade
Image text-base: 0x40008F90, data-base: 0x41878000
Harold Ritter
BGP update-groups (AKA dynamic update peer-groups) is a BGP optimization that allows the router to process an update once and send it to a group of neighbor that share a common outbound policy. This is done without additional configuration contrary to peer-groups.
To see which neighbors are member of a given update-group, use the "show ip bgp update-group " command as follow:
r1#sh ip bgp update-group 1
BGP version 4 update-group 1, internal, Address Family: IPv4 Unicast
BGP Update version : 6, messages 0/0
Update messages formatted 4, replicated 0
Number of NLRIs in the update sent: max 0, min 0
Minimum time between advertisement runs is 5 seconds
Has 1 member (* indicates the members currently being sent updates):
2.2.2.2
For more information on this feature, refer to the following URL:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1829/products_feature_guide09186a008012ed14.html
Hope this helps,
hritter,
Thanks for the information. So,from what you stated there is no need for any BGP configuration in order
to benefit from that new feature. In that regard, what is the meaning of the 7 update groups in the sngbbr1 case. Does it indicate that 7 groups get build and each need to be displayed by using the sh ip bgp update-group xx ?
BGP routing table entry for 192.25.155.9/32, version 465794
1 2 3 4 5 6 7
