03-30-2005 02:25 PM - edited 03-03-2019 09:10 AM
Hello
I'm trying to configure a 1760 VPN-K9. The fastethernet port receive an IP from the cable modem from my ISP. The problem is that I cannot ping any thing on the internet except the ISP Gateway. Can you help me please.
Thank you
03-30-2005 04:38 PM
Are you able to serf the internet????
If yes and still you are not able to ping any site..most probably icmp is blocked from the isp end.
Do post your configuration to understand well...
Good Luck
03-30-2005 07:31 PM
No I can't go on the internet. There is my configuration.
version 12.3
service config
hostname ****
boot-start-marker
boot-end-marker
logging buffered 52000 debugging
enable secret ***
enable password *****
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip ips po max-events 100
ip dhcp-server 24.200.242.21
ip dhcp-server 10.0.0.1
no ftp-server write-enable
interface FastEthernet0/0
description $ETH-WAN$
ip address dhcp client-id FastEthernet0/0
ip mask-reply
ip directed-broadcast
ip virtual-reassembly
speed auto
full-duplex
vlan-id dot1q 1
exit-vlan-config
interface FastEthernet0/1
switchport access vlan 2
no ip address
vlan-id dot1q 1
pppoe enable
exit-vlan-config
no cdp enable
interface FastEthernet0/2
no ip address
no cdp enable
interface Vlan1
ip address 10.0.0.5 255.0.0.0
interface Vlan2
no ip address
ip mask-reply
ip nat inside
shutdown
router rip
passive-interface FastEthernet0/0
passive-interface Vlan1
network 10.0.0.0
network 24.0.0.0
no auto-summary
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat pool test 10.0.0.1 10.0.0.20 netmask 255.0.0.0
access-list 1 remark test
access-list 1 remark SDM_
access-list 1 permit any
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server enable traps tty
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
privilege level 15
password *****
login local
transport input telnet ssh
line vty 5 15
privilege level 15
password *****
login local
end
Thank you very much for your help.
Patrick
03-31-2005 07:49 AM
The biggest problem that I see is that there is no default route. You can confirm whether this is the case by posting the output of show ip route.
The easy way to fix this is to configure a static default route pointing to the ISP. It could be of the form:
ip route 0.0.0.0 0.0.0.0
assuming that you know the address of the ISP to which you are connected. We might guess that it is 24.200.242.21 based on the configuration of the DHCP server.
or the default route can have the form:
ip route 0.0.0.0 0.0.0.0 FastEthernet 0/0
which would be best if you do not know the ISP address. The biggest disadvantage of this form is that it requires the router to ARP for every remote address to which it is forwarding and assumes that the ISP will proxy ARP for all these (and some providers will not proxy ARP).
There are a few other things like why do you have both enable password and enable secret? And why do you have VLAN 2 shut down? But these are not particularly important to your question about accessing the Internet.
Rick
