Need for HSRP in VSS
Hello
I am new to VSS i have been through the configuration and features of VSS. I have an experience of configuring VSS on 4500-X switches. Configuration was pretty straight and good.
But i want to know what is the advantage in configuring HSRP when there is VSS. As per my understanding the same configuration which is on primary/Active switch will be on passive switch if it goes down including the hostname. In this case what is that i can do with HSRP.
Can anyone tell me does that really make sense if we configure HSRP in VSS environment will that be of any advantage?
6 Replies 6
InayathUlla Sharieff
Here is your answer;
Have a look at this post:
https://supportforums.cisco.com/thread/2144055
**** Please dont forget to rate usefull posts********
Totally Agree!! so HSRP has a role in VSS if there are more than two players.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Oh, think situations where you want/need more than two routers in a HSRP group or where you might need to replace the whole VSS setup.
Hi Joesph
Agree with you. !! Will it be possible to form more than  2 switches in a VSS domain.
RAj,
Answer is NO.
And Need for HSRP in VSS described in my earlier post which gives clear explanation.
