Need help Configuring 1941 w/ csu/dsu module
morales0056434
I am still very new to configuring Cisco equpment and am need of some help configuring a 1941 router with a csu/dsu module. I am directly connected to the T1 jack and verified a connection with the hardware loopback button.
i've gathered code from various Cisco/Online resources and cannot figure out what I need to do.
My goal is simply to be able to go out to the internet from an internal network.
any help would be most apreciated,  thanks in advance
Below is the info I recieved from the ISP:
ROUTER IP INFO:
IP Address: xxx.xxx.xxx.xxx
Subnet: 255.255.255.252
Gateway: xxx.xxx.xxx.xxx
Primary DNS: xxx.xx.xxx.xxx
Secondary DNS: xxx.xx.xxx.xxx
DLCI#: xxxIETF
VERIZON INFORMATION:
Network Range: xxx.xxx.xxx.xxx/x0
Circuit# (ID): xxxxxxxxxxxxxxxx
Circuit#: xx/xxxx/xxxxxx/xx
And my current config:
version 15.0
service udp-small-servers
service tcp-small-servers
hostname Cisco1
boot-start-marker
boot-end-marker
enable password admin1
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool mainip
   import all
   network x.x.0.0 255.255.255.0
   dns-server x.x.x.x
   default-router x.x.x.x
   lease 5
license udi pid CISCO1941/K9 sn xxxxxxxxxxxxx
interface GigabitEthernet0/0
ip address x.x.x.x 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address x.x.x.x 255.255.255.252
ip nat outside
encapsulation frame-relay IETF
no clock rate 2000000
service-module t1 timeslots 1-24
frame-relay map ip x.x.x.x. xxx broadcast IETF
router eigrp 1000
network x.x.0.0
network x.x.0.0
network x.x.x.0
network x.x.x.x.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
5 Replies 5
Richard Burts
Israel
You are off to a good start. The biggest issue that I see in this config is that while you have specified ip nat inside and ip nat outside on appropriate interfaces that there is no statement to invoke address translation. It might look something like this:
ip nat inside source list 15 interface Serial0/0/0 overload
access-list 15 permit x.x.x.x 0.0.0.255
I would also think that there is some value in configuring a serial interface subinterface and moving the IP address and the DLCI from the physical interface (where it is essentially a multipoint interface) to the serial subinterface where it will be a true point to point interface.
Rick
[edit] I notice that you have configured EIGRP as a dynamic routing protocol. This may be a good thing. I also notice that there are multiple network statements under router EIGRP. But the way that you have masked "sensitive" information makes it difficult to know what networks you intend to put under EIGRP. And having multiple network statemets when there are only 2 networks configured on the router (and one of them is to outside where you probeably do not want to run your internal routing protocol) seems pretty strange. Perhaps you can clarify what you are trying to do with EIGRP?
Rick
Thank you for the response Rick,
I will add the NAT statements and also I have added the and subinterface, see below:
no ip address
interface Serial0/0/0.1
ip nat outside
encapsulation frame-relay interface-dlci xxx IETF
would I then change the Ip route to point to the sub interface?:
ip route 0.0.0.0 0.0.0.0 Serial0/0/0.1
As for the EIGRP,  it was an attempt to get some sort of reply from a neighbor router and I would like to remove it entirely if it isnt 100% required to get internet access.
thanks again for your help
Israel
Yes you would change the static route to point to the subinterface.
Where is the neighbor router? (on what interface is it connected?) If it is on the inside interface then it might make sense to run EIGRP (assuming that the neighbor is also running EIGRP and is using the same AS# in its EIGRP config). The serial interface goes to your service provider and generally you would not want to run a protocol like EIGRP with your provider.
One other important thing to understand about configuring EIGRP is that you use network statements to identify networks on local interfaces that you want to be running EIGRP. Since it looks like you have only one interface where you might want to run EIGRP I would expect only one network statement under router eigrp.
Rick
Rick
Rick,
You were correct,  I was trying to set up EIGRP with the porvider and realized it wasnt what i need to do,  i removed it rom my config completely.
So I have finally have a way to the internet from the router,  I can ping google from the console.  But it seems my NAT is not functioning properly.
Any ideas?
Building configuration...
Current configuration : 1419 bytes
! Last configuration change at 17:51:09 UTC Tue Nov 16 2010
version 15.0
hostname Cisco1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool internal
   network 1.1.0.0 255.255.255.0
   default-router 2.2.2.2
   domain-name name.server
   lease 7
ip name-server 3.3.3.1       --------Primary DNS
ip name-server 3.3.3.2       --------Secondary DNS
license udi pid CISCO1941/K9 sn FTX143802RG
ip address 1.1.0.1 255.255.255.0
ip access-group 1 in
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
mtu 4470
ip address 4.4.4.2 255.255.255.252
ip access-group 1 out
ip nat outside
traffic-shape rate 1024000 25600 25600 1000
no ip http server
ip route 0.0.0.0 0.0.0.0 4.4.4.1   ----------Gateway
ip nat inside source list 1 interface Serial0/0/0 overload
access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Israel
I am not sure that the problem is NAT. I believe that the problem is in the way that you configured the router to act as a DHCP server. Here is what I see in the config:
You are telling the client PCs to use addresses in network 1.1.0.x and that their default gateway is in an entirely different network. The default gateway in the DHCP pool should be the address of the router interface (in this case 1.1.0.1).
While I am responding let me comment on a few other things. I am surprised that you are using network 1.1.0 as the network on your LAN interface. Is there a reason for doing this? The more common approach is to configure your LAN with private addresses (such as 192.168.x.x, or 172.16.y.y, or even 10.z.z.z).
I would also suggest that it might be better if you use access list 1 differently. As currently configured access list 1 is used as an inbound filter on the LAN interface, used as an outbound filter on the WAN interface, and is used for NAT. It will constrain what you can do as your router config needs to adapt to changes that may take place in your network.
I would also comment that if the access list is going to permit any that there is very little reason to use it as an inbound filter on the LAN or an outbound filter on the WAN. If you are going to permit everything there is little reason to configure the access-group on those interfaces.
I would also suggest that you configure the access list differently. I have seen some unexpected behaviors when access lists used for NAT are configured with permit any. I would suggest that it would be better if the access list permitted the subnet of the LAN interface. In your current config that would be access-list 1 permit 1.1.0.0 0.0.0.255
Rick
[edit] I just re-read your post and see one other issue. In your NAT statement you are using the physical interface for the overload. You should be specifying the subinterface as the overload.
Rick
