Private and public VLAN - 3560 or 3750
zrob12ynyng
Can I have one VLAN NAT'ing private IPs to routable IPs and another VLAN that passes traffic straight through on public IP addresses on a 3560 or 3750 switch?
Peter Paluch
Hi Zach,
To my best knowledge, this cannot be done on 3560/3750 series because neither of them actually supports the Network Address Translation. Sorry to disappoint you in this way.
However, can you tell us why do you need such design? Perhaps we could find an alternate solution.
Best regards,
Peter
Any recommendations on a router that can handle this? I currently have a 1811 on a 45/45 circuit, but looking to upgrade to 100/100.
A ISR 18XX router is not designed to handle a 45 Mbps link and as you are going to upgrade to a 100 Mbps a ISR-G2 39XX will be perfect for you.
Sai.
Looking at purchasing a 3925 router. What is the difference between the
3925 and 3925E?
My network will be one 100/100 Metro Ethernet circuit as into one WAN. I will also need 8 LAN ports.
