Need help configuring site-to-site VPN
Akila
I'm trying to connect 2 sites to the main office in the middle using VPN I already configured the left side and It works fine but I can't seem to connect the right side to the middle network, here are all the configuration commands i used,
!on router 6 (left)
hostname S
interface g0/1 ip address 10.1.18.1 255.255.255.224
no shut
interface g0/0 ip address 1.0.0.2 255.255.255.224
no shut
exit ip route 0.0.0.0 0.0.0.0 1.0.0.1
!on router 7(middle)
hostname B
interface g0/1
ip address 10.0.18.1 255.255.255.224
no shut
interface g0/0
ip address 2.0.0.2 255.255.255.224
no shut
exit
ip route 0.0.0.0 0.0.0.0 2.0.0.1
!router 8 (right)
hostname M
interface g0/1
ip address 10.2.18.1
no shut
interface g0/0
ip address 3.0.0.2
no shut
exit
ip route 0.0.0.0 0.0.0.0 3.0.0.1
!on router 5 (ISP, top)
hostname ISP
interface g0/0
ip address 1.0.0.1 255.255.255.224
no shut
interface g0/1
ip address 2.0.0.1 255.255.255.224
no shut
interface g0/2
ip address 3.0.0.1 255.255.255.224
no shut
exit
!on router M , B, S
license boot module c1900 technology-package securityk9
!on router 6
crypto isakmp policy 10
encryption aes 256
authentication pre-share
group 5
crypto isakmp key secretkey address 2.0.0.2
crypto ipsec transform-set S-B esp-aes 256 esp-sha-hmac
crypto map IPSEC-MAP 10 ipsec-isakmp
set peer 2.0.0.2
set pfs group5
set security-association lifetime seconds 86400
set transform-set S-B
match address 100
interface GigabitEthernet0/0
access-list 100 permit ip 10.1.18.0 0.0.0.31 10.0.18.0 0.0.0.31
!for the 1st tunnel
encryption aes 256
group 5
crypto isakmp key secretkey address 1.0.0.2
crypto ipsec transform-set B-S esp-aes 256 esp-sha-hmac
set peer 1.0.0.2
set pfs group5
set transform-set B-S
match address 100
access-list 100 permit ip 10.0.18.0 0.0.0.31 10.1.18.0 0.0.0.31
!for the 2st tunnel
crypto isakmp policy 11
encryption aes 256
group 5
crypto isakmp key secretkey address 3.0.0.2
crypto ipsec transform-set B-M esp-aes 256 esp-sha-hmac
crypto map IPSEC-MAP 11 ipsec-isakmp
set peer 3.0.0.2
set pfs group5
set transform-set B-M
match address 110
access-list 110 permit ip 10.0.18.0 0.0.0.31 10.2.18.0 0.0.0.31
!on router 8(left)
encryption aes 256
group 5
crypto ipsec transform-set M-B esp-aes 256 esp-sha-hmac
set peer 2.0.0.2
set pfs group5
set transform-set M-B
match address 110
access-list 110 permit ip 10.2.18.0 0.0.0.31 10.0.18.0 0.0.0.31
I opened the file and both VPNs are working. What exactly can you NOT do ? If I ping 10.0.18.2 from both VPN endpoints, I get a proper response, and if you check the encrypted packets on R7 with 'show crypto ipsec sa', the encrypted packet count is increasing.
I have taken out all the redundant stuff and cleaned up the configs, revised project file is attached...(use the lateste version of Packet Tracer, 7.2.2).
10 Replies 10
post the Packet Tracer project (.pkt) file, zip it first, otherwise the system won't let you upload it.
thank you for your reply, it seems to be working on your revised lab, could it be an issue with the packt tracer version? or did you change any configurations?
thank you
I just restarted the application and it seems to be working fine, thank you very much for your time, good sir.
and if you have time could you please explain how can I add a remote user to connect to the 10.0.18.0 network through IP Sec VPN, thank you
if you add the lines in bold to the configuration of Router7, the router will function as PPTP VPN server for remote access users:
Current configuration : 1554 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname B
username vpnuser password 0 vpnpassword
aaa new-model
aaa authentication ppp default local
vpdn enable
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15245NGO-
vpdn-group REMOTE-VPN
accept-dialin
protocol pptp
virtual-template 1
encr aes 256
group 5
encr aes 256
group 5
crypto isakmp key secretkey1 address 3.0.0.2
set peer 1.0.0.2
set pfs group5
match address 100
set peer 3.0.0.2
set pfs group5
match address 101
spanning-tree mode pvst
duplex auto
speed auto
interface GigabitEthernet0/1
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered GigabitEthernet0/1
peer default ip address pool VPNPOOL
ppp encrypt mppe auto required
ppp authentication ms-chap ms-chap-v2
interface Vlan1
no ip address
shutdown
ip local pool VPNPOOL 10.0.18.20 10.0.18.30
ip classless
ip flow-export version 9
access-list 101 permit ip 10.0.18.0 0.0.0.31 10.2.18.0 0.0.0.31
line con 0
line aux 0
line vty 0 4
login
end
Protocol PPTP is not available,
I attached the pkt file
Thank you
the only option available as protocol appears to be pppoe, but that is not supported in Packet Tracer. EZVPN is not supported either. What is the exact requirement for the remote access ?
Keep in mind that Packet Tracer devices are not fully featured, real IOS devices. Only a subset of the commands available in IOS are available.
the requirement is that the remote users should be able to access their work from the company site (10.1.18.0 network and 10.2.18.0 network) while traveling.
have a look at the video below. As said, you can only do a few things with Packet Tracer, the below might work for you:
Packet Tracer Lab 6 - Remote Access VPN
https://www.youtube.com/watch?v=lkUq6Pl6his
The sixth video in a series that demonstrates how to configure network infrastructure devices using Cisco Packet Tracer. Each video in the series builds upon the previous video, the network evolves step by step introducing important principles and technologies. This video looks at configuring a ...
