06-12-2015 12:44 AM - edited 03-05-2019 01:39 AM
I need help to configure a Cisco router 867VAE K9.
I have a DSL line and the internal network. I just want to access internet in internal network.
My configuration work's but for some sites access is very slow.
Here is my config :
Current configuration : 5594 bytes
! Last configuration change at 14:23:44 Paris Thu Jun 11 2015 by cisco
version 15.3
no service pad
hostname XXXXX
boot-start-marker
boot config usbflash0:CVO-BOOT.CFG
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
wan mode dsl
clock timezone Paris 1 0
no ip domain lookup
ip domain name home.int
ip name-server 212.27.40.240
ip name-server 212.27.40.241
ip cef
no ipv6 cef
vpdn enable
crypto pki trustpoint TP-self-signed-2069868063
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2069868063
revocation-check none
rsakeypair TP-self-signed-2069868063
crypto pki certificate chain TP-self-signed-2069868063
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32303639 38363830 3633301E 170D3134 31323330 30303535
XXXXXXXX XXXXXXXX XXXXXXX .......
quit
username xxxxx privilege 15 secret 5 $xxxxxxx/xxxxxxxx
username xxxxx privilege 15 secret 5 $xxxxxxx/xxxxxxxx.
controller VDSL 0
crypto isakmp policy 3
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group vpngroup
key xxxxxxx
dns 192.168.10.10
wins 192.168.10.10
domain xxxxxxx.local
pool default
acl 102
crypto ipsec transform-set myset esp-3des esp-md5-hmac
mode tunnel
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
ip address x.x.x.x 255.255.255.0
ip nat outside
ip virtual-reassembly in
pvc 8/36
encapsulation aal5mux ip
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
description $ES_WAN$$FW_OUTSIDE$
no ip dhcp client request tftp-server-address
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
shutdown
duplex auto
speed auto
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.10.254 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.10.252 22 interface ATM0.1 22
ip nat inside source static tcp 192.168.10.252 1300 interface ATM0.1 1300
ip nat inside source static udp 192.168.10.252 4500 interface ATM0.1 4500
ip nat inside source static udp 192.168.10.252 500 interface ATM0.1 500
ip nat inside source static tcp 192.168.10.252 4500 interface ATM0.1 4500
ip nat inside source static tcp 192.168.10.252 500 interface ATM0.1 500
ip nat inside source static tcp 192.168.10.10 443 interface ATM0.1 443
ip nat inside source static tcp 192.168.10.10 25 interface ATM0.1 25
ip nat inside source static tcp 192.168.10.10 4125 interface ATM0.1 4125
ip nat inside source list 101 interface ATM0.1 overload
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip route 10.1.1.248 255.255.255.255 192.168.10.248
ip route 10.1.8.21 255.255.255.255 192.168.10.248
ip route 172.31.0.0 255.255.0.0 192.168.10.248
mac-address-table aging-time 16
no cdp run
access-list 1 permit 10.10.10.0 0.0.0.7
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.10.0 0.0.0.255
access-list 101 deny ip any 10.0.0.0 0.255.255.255
access-list 101 deny ip any 192.168.0.0 0.0.255.255
access-list 101 permit ip any any
access-list 102 permit ip 192.168.10.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 102 permit ip 10.0.0.0 0.255.255.255 192.168.10.0 0.0.0.255
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler allocate 60000 1000
end
In the beginning, there was this line in Vlan1 configuration (in the basic config) : "ip tcp adjust-mss 1452".
With this line on internal network interface configuration, the connection work's but a lot of sites are unavailable or very very slow.....
So, i imagine that the problem is about this.
Also, i have seen in the configuration of the old routeur (cisco 837) , lines like this : " hold-queue 100 out", "hold-queue 224 in"
What is it ? And is it necessary ?
Can you help me ?
Thanks.
