Need help for Dual pppoe WAN on Cisco 1841
trakimanhminh
Hi everyone!
I got an issue with the configuration on Cisco 1841. I have two pppoe WAN, and config IPSLA to run failover. But when the ISP-1 down, I can't connect to the internet through ISP-2. Here is my full configuration:
Building configuration...
Current configuration : 3179 bytes
! Last configuration change at 15:00:09 UTC Thu Sep 6 2018
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.5
ip dhcp excluded-address 192.168.10.1 192.168.10.5
ip dhcp pool vlan1
network 192.168.10.0 255.255.255.0
default-router 192.168.1.1
dns-server 208.67.220.220 208.67.222.222
ip dhcp pool 1
network 192.168.1.0 255.255.255.0
ip cef
no ipv6 cef
license udi pid CISCO1841 sn FHK144573U8
redundancy
track 10 ip sla 1 reachability
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
ip tcp adjust-mss 1452
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0/1/0
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 2
no cdp enable
interface FastEthernet0/1/1
ip nat inside
ip nat enable
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/0/0
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Dialer1
ip address negotiated
ip mtu 1454
ip nat outside
ip nat enable
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname xxxxxxxx
ppp chap password 0 xxxxxxx
ppp pap sent-username xxxxxxxxx password 0 xxxxxxxxx
no cdp enable
interface Dialer2
ip mtu 1454
ip nat outside
ip nat enable
encapsulation ppp
dialer pool 2
dialer-group 2
ppp chap hostname xxxxxxxxxxxxxxxx
ppp chap password 0 xxxxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxx password 0 xxxxxxxxxxx
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map FPT interface Dialer2 overload
ip nat inside source route-map VNPT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 Dialer2 2
ip sla 1
icmp-echo 208.67.222.222 source-interface Dialer1
threshold 500
frequency 10
ip sla schedule 1 life forever start-time now
access-list 1 permit any
route-map VNPT permit 1
match ip address 100
match interface Dialer1
route-map FPT permit 1
match interface Dialer2
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Please advice me in this case.
Thanks all for the helps!
5 Accepted Solutions
looks like a simple typo:
needs to be:
ip route 0.0.0.0 0.0.0.0 Dialer1 track 10
I have just used your advice but it's still no use! Any correction for my configuration here, friend?
in addition, add the EEM script below, otherwise your NAT entries will have to timeout before the failover:
event manager applet CLEAR_NAT
event track 10 state any
action 1.0 cli command “enable”
action 2.0 cli command “clear ip nat translation *”
Your access list is incorrect. Use the config below:
access-list 1 permit 192.168.10.0 0.0.0.255
match ip address 1
match ip address 1
I really appreciate for your help. I have fixed the configuration follow your advice and now my router is working perfectly.
Thanks again for your help!
5 Replies 5
needs to be:
match ip address 1
match ip address 1
