Need help in determining a router model
jachowda
Hi all, i need to find a router which will support all the features mentioned below. Please help me in this case.
8 PORT ROUTER::
1. Base Configuration: Router Dual 1O/lOOBaseTX ports, One NSM slot, 2 WAN port card slots & support for hardware mini Accelerator card.
2.Supported Optional WAN/LAN Modules:
Channelized El/T1, PRI, BRI, Sync
(2Mbps), Async,Ethernet Ports, FXO,FXS ports.
3.Supported Optional NSM modules:
4/8 port BRI modules. Blank WAN port NSM modules.
4.System: *High performance 80MHz RISC processor
*128MB SDRAM upgradeable to 512MB.
*16MB Flash expandeable upto 192MB.
5.Supported Routed Protocol:
IP, IPv6, IPX/SPX (including Spoofing), Apple Talk, DECNET
6.Supported Routing Protocols:
Static routes, RIP, OSPF, BGP4
7.Supported WAN Protocols:
Frame Relay, X.25, PPP, PPPoE client and server.
8.QOS featurs:
Traffic Shaping, Packet Priority, RSVP.
9.Supported tunneling & Security:
NAT, Packet filtering, L2TP access concentrator, L2TP network server, Stateful Inspection Firewall, HTTP Proxy, SMTP Proxy, DES Encryption hardware (optional), Triple DES Encryption hardware (optional), IPSec, IKE, PKI.
10.Authentication:
PAP, CHAP,RADIUS, TACACS authentication.
11.Supported Multicasting:
IGMP, PIM-SM (on lPv4 and IPv6), PIM-DM (on IPv4 and lPv6), DVMRP (on IPv4 and IPv6).
12.Advanced features:
Router should support multiple Configuration & Release Files on Flash for redundancy & Should have build-in Email Client. Router should support Time, Date, Weekend & Event based QOS,
Filtering, Policies & Routing.
13.Management:
Console port, Command Line Interface (CLI), Telnet, Web browser, SNMP, Scripts Local and remote logging, Configuration loading by TFTP, HTTP, Zmodem.
14.Power:
Max Power Consumption: 25W, 2A
Goutam Sanyal
Level 4
Level 4
Jaganmohan Chowdam,
You can check your requirements at the following link
http://tools.cisco.com/ITDIT/CFN
Goutam
