Need help on deciding the part number for cisco fan tray
redindian
I have a switch with part number WS-C4006-S2 , and the fan tray for this switch is faulty, however,i do not know the part number for the fan tray, furthermore, i have found one fan tray's part number in cisco website, WS-X4005= with description :Catalyst 4006 Fan Tray (Spare);my question is i would like know whether WS-X4005= is the correct fan tray for WS-C4006-S2 .
aghaznavi
Level 5
Level 5
You can find the fan tray serial and part numbers, as shown in this photograph. The label is located on the outside sheet metal of the fan tray, which is typically on the back of the fan tray
http://www.cisco.com/en/US/products/hw/optical/ps2006/products_tech_note09186a0080094523.shtml#t4
Edison Ortiz
Yes, that fan will meet your needs.
HTH,
