need help! Problem w/ Policy Based Routing in 2 ISP
Jaccobbchoi
Hi to all Netpro users,
I have this problem. Im using Policy Based routing on 2 ISP. As you see on the network diagram. im using flat network. dividing the 2 block of ip address. BLock 1 on ISP 2 and Block 1 on ISP1. At the same time im doing a vpn site to site w/ a linksys router on one of the remote branches using the ISP2. I want the remote dialup vpn also to connect on ISP2 + adding up Portforwading on ISP2. The ISP1 will serve as a backup of the VPN site to site and remote dialup vpn. When the user from vpn site to site and remote dialup connects to the Block2 users there is no problem but they cannot connect to the block1. vice versa. Attached is the config and the diagram. Pls review and help me. Thanks in advane.
