Need help setting up Cisco 891f router for basic internet
peterspliid
I have a Cisco 891f with a switch module, so it has 8 gigabit ethernet ports. I have set up dhcp, which I cannot get to work either. When I connect it to my pc, I get a seemingly random ip address, like 169.254.114.181, which has nothing to do with my DHCP. Even if I manually set the IP on my PC, I still cannot get internert through. EDIT: DHCP seems to work, it apparently just needed some time to give me a correct IP
It is connected to the internet from Gi 8, which should obtain an IP using DHCP. It seems to be obtaining the IP address correctly
Here's my config
! Last configuration change at 09:35:16 UTC Sat Feb 9 2019
version 15.3
hostname ErcoRouter
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
enable secret 5 $1$kItV$IyWuNF.qiGbt1wM9ddMdH/
no aaa new-model
ip dhcp excluded-address 192.168.1.1 192.168.1.12
ip dhcp pool ippool
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8 8.8.4.4
default-router 192.168.1.1
no ip domain lookup
ip domain name erco.dk
ip cef
no ipv6 cef
license udi pid C891F-K9 sn FCZ224410K3
username peter password 0 ******
ip ssh version 2
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Async3
no ip address
encapsulation slip
router rip
version 2
network 192.168.1.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
scheduler allocate 20000 1000
end
on a side note, you want to configure 'spanning-tree portfast' on your switchports in order for the DHCP to work faster, if you have end users (e.g. PCs) connected. Also, I am not sure if you need the RIP config, unless you have other routing devices connected to your 891F, you don't need RIP.
So the entire config would look like below (important parts maked in bold):
version 15.3
hostname ErcoRouter
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
no aaa new-model
ip dhcp pool ippool
no ip domain lookup
ip cef
no ipv6 cef
ip ssh version 2
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Async3
no ip address
encapsulation slip
--> no router rip
version 2
network 192.168.1.0
no ip http server
ip route 0.0.0.0 0.0.0.0 dhcp
ip nat inside source list 1 interface GigabitEthernet8 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
Francesco Molino
First of all, i would use ip route 0.0.0.0 0.0.0.0 dhcp instead of the one used in your actual config.
Then you're missing the nat configuration. Add the following commands:
ip access-list extended NAT
permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list NAT interface gig8 overload
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Thank you very much for your help
version 15.3
hostname ErcoRouter
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
no aaa new-model
ip dhcp pool ippool
no ip domain lookup
ip cef
no ipv6 cef
ip ssh version 2
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Async3
no ip address
encapsulation slip
--> no router rip
version 2
network 192.168.1.0
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
This fixed, and thank you for the DHCP tip
