can reach different subnets between two routers?
baselzind
Level 6
Level 6
i have server1 in "network 1 vlan30" behind a router "CME" which is  its default gateway also it is a cme , im trying to reach server2 "network 2 vlan 1" in an another subnet behind another router"R1" which is also server 2 default gateway , i can reach server 2 from server 1 but i cant reach server 1 from server 2?
also server 1 can ping R1 network 2 address
and server 2 can ping cme network 1 address
could it be because cme just have a interface vlan for network 2 on it not a physical port?
balaji.bandi
Do you have Routing from server 1 from server 2
Like you have route below ?
ip route 10.0.0.0 255.255.255.0 20.0.0.254
BB
from server 1 from server 2? can you rephrase the question please
The diagram doesn't match the config of the routers CME and R1 and the configs also look incomplete in regard to forwarding/NAT. Please draw a new diagram with complete interface- and IP information how the network should be implemented and then we can go on troubleshooting that.
