Need help to understand the ouput of show ip cef internal command
Steph1963
I am having a bit of difficulties to understand the following output of show ip cef internal command:
1) Can somebody explain me the meaning of the hash value and more important how it is used by cef to route packet when multiple interface are available.
2) Also would like to understand the meaning of the  0 packets, 0 bytes in red. Does that means that no packets has been routed? The packet column beside the point2point  column is all zero, is there any special reason why?
3) Is there a command that would indicate where a packet would be routed  based on the destination prefix for a case where the router is doing some load sharing.
Thanks for your help
Stephane
a1#show ip cef 192.168.0.0 internal
192.168.0.0/24, version 33, epoch 0, per-destination sharing
0 packets, 0 bytes
via 172.16.0.21, Serial0/0/0.100, 0 dependencies
traffic share 1
next hop 172.16.0.21, Serial0/0/0.100
valid adjacency
via 172.16.0.21, Serial0/0/0.200, 0 dependencies
traffic share 1
next hop 172.16.0.21, Serial0/0/0.200
valid adjacency
0 packets, 0 bytes switched through the prefix
tmstats: external 0 packets, 0 bytes
internal 0 packets, 0 bytes
Load distribution: 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 (refcount 1)
Hash      OK      Interface                Address           Packets
1           Y          Serial0/0/0.100      point2point          0
2           Y          Serial0/0/0.200      point2point           0
3           Y          Serial0/0/0.100      point2point           0
4           Y          Serial0/0/0.200      point2point           0
5           Y          Serial0/0/0.100      point2point          0
6           Y          Serial0/0/0.200      point2point           0
7           Y          Serial0/0/0.100      point2point          0
8           Y          Serial0/0/0.200      point2point           0
9           Y          Serial0/0/0.100      point2point           0
10         Y          Serial0/0/0.200      point2point           0
11         Y          Serial0/0/0.100      point2point           0
12         Y          Serial0/0/0.200      point2point           0
13         Y          Serial0/0/0.100      point2point           0
14         Y          Serial0/0/0.200      point2point           0
15         Y          Serial0/0/0.100      point2point           0
16         Y          Serial0/0/0.200      point2point           0
milan.kulik
Level 10
Level 10
ad 1) The hash function is applied on the IP source/destinatiom pair of the packet forwarded. Depending on the hash result, it takes the particular path.
See
in your case: Packets with hash odd values are taking one path while packets with even hash values are taking the other path.
ad 2) I don't think 0 counters mean 0 packets routed here. But I don't know the correct answer.
ad 3) show ip cef exact-route source_ip dest_ip
is the command you are looking for.
HTH,
Milan
