Need help with Cisco 867vae-k9 with Sub interfaces on WAN interface
sunil.talluri1
Need support wheather cisco 867vae support sub interface config on WAN PORT.
if yes need some configuration templet..
I suppose to take two services from single ISP.
what do you mean by two services from one ISP ?
Below is a sample config with two ATM subinterfaces, each bound to a different dialer:
Current configuration : 4151 bytes
version 15.7
no service pad
hostname R1-C867VAE
boot-start-marker
boot-end-marker
enable secret 5 $1$0VER$cRREqm1C6s8bxyxv64IJS/
no aaa new-model
wan mode dsl
clock timezone GMT 12 0
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
ip domain name mydomain.com
ip cef
no ipv6 cef
username Admin password 7 12090404011C03162E
controller VDSL 0
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 0/100
pppoe-client dial-pool-number 1
interface ATM0.2 point-to-point
pvc 0/101
pppoe-client dial-pool-number 2
interface Ethernet0
no ip address
zone-member security DMZ
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
load-interval 30
interface Dialer0
no ip address
interface Dialer1
ip address negotiated
ip nat outside
ip mtu 1452
encapsulation ppp
ip tcp adjust-mss 1412
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ppp
ppp chap password 7 06575D72181B5F
ppp pap sent-username ppp password 7 00554155500E5D
interface Dialer2
ip nat outside
ip mtu 1452
encapsulation ppp
dialer pool 2
dialer-group 1
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer 1 overload
ip dns server
ip route 0.0.0.0 0.0.0.0 Dialer 1
access-list 1 permit 1.1.1.0 0.0.0.255
dialer-list 1 protocol ip permit
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input none
scheduler allocate 60000 1000
end
Add tags
Two service means one is internet service and other one vpn circuit.for both services they will tag two different vlans..so I need to configure two sub-interface configuration ..
