Need help with DHCP and intervlan on cisco switch 3550
jdave2780
I am trying to setup my 3550 layer 3 switch to do hand out dhcp addresses for different vlans.  It is connected to my router address 192.168.1.1.  I setup a new vlan 3 and the dhcp pool.. The client gets a 192.168.3.2 address but am not able to ping the router and other clients and get out to the internet.  What am I doing wrong?  I will appreciate any help or advice.  Here is the config that I have.  I deleted the other ports because I am not using them.  The vlan 3 client is on port fast Ethernet 0/17 and the router is connected to the fastethernet 0/1.  Thanks in advance.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW3
no aaa new-model
ip subnet-zero
ip routing
no ip domain-lookup
ip dhcp pool VOICE_VLAN
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   dns-server 192.168.1.1
   option 150 ip 192.168.3.1
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/17
switchport access vlan 3
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.1.223 255.255.255.0
interface Vlan3
ip address 192.168.3.1 255.255.255.0
ip default-gateway 192.168.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http secure-server
control-plane
line con 0
exec-timeout 0 0
line vty 0 4
no login
line vty 5 15
no login
end
2 Accepted Solutions
Rahul Kukreja
Jay -
To me it looks like -
For VLAN 1 - default gateway is 192.168.1.1 (Router)
For VLAN 3 - default gateway is 192.168.3.1 (SW)
so when VLAN 3 users try to talk to Router IP 192.168.1.1, then the traffic goes to the Router (via the SW which is the default gateway for users in VLAN 3)
But as you specified that there is no back route for 192.168.3.0/24 on router - the traffic destined to this subnet on Router will go the default route and the pings are never going to work between these 2 VLAN's.
So to avoid this, you will need to have the default gateway for both the VLAN's on the SW (as the router is not managed)
Rahul
Jay Dave, couple items... you said that nothing from vlan 1 can reach vlan 3 and vice versa?  I don't think that's accurate.  I would bet if you connected a computer to fa0/2  and assigned it an IP adress of 192.168.1.200/24 and a default gateway of 192.168.1.223, you will be able to ping 192.168.1.1, 192.168.3.1 and 192.168.3.2.  The problem as noted by others is that there is no route or proper gateway address on your verizon modem so the packets are getting to the modem, but he has no idea how to get back to 192.168.3.x.  Can you see if you can access or have verizon put in a route or Default Gateway entry on the verizon modems inside interface that points to 192.168.1.223 ?  or a route like this on the modem.
ip route 192.168.3.0 255.255.255.0 192.168.1.223
12 Replies 12
cadet alain
Does the router have a route back to the 192.168.3.0/24 subnet ?
Regards.
Alain
No, it is a basic Verizon modem. The verizon box only handles the 182.168.1.0 network. Can I configure it to do that on the switch? Or should I setup router on a stick and add that in between the switch and verizon modem? I was trying to see if I can do it all from the switch.
Sorry a typo on the network it should be 192.168.1.0.
ok so finally which subnet are the clients in and which subnet is the router in ?
Regards.
Alain
Some clients and router is on the 192.168.1.0 network and the client I am testing is on the 192.168.3.0. Hope that helps.
Can the clients in the 192.168.1.x network ping both 192.168.1.1 and 192.168.1.223 ?
The results from the following commands would be helpful >
sh ip int br
sh int status
Also, why do you have Fa0/1 setup as a trunk?   You said it's a basic verizon modem?  is it a DSL/Cable modem?
If so, change fa0/1 it to an access port  >
no switchport mode trunk
no switchport trunk encapsulation dot1q
switchport access vlan 1
Yes the clients on the 192.168.1.0 network reach 192.168.1.1 and 1.223. But nothing from the 3.0 can reach 1.0 network and vice versa. Also when I do a tracert from 3.2 to 192.168.1.1 it stops at 192.168.3.1. So there is something I am missing. But don't know what, I turned in the ip routing. And also I reconfigured the fa 0/1 to be access instead if a trunk.
Please show us the relevant results from the following >
sh ip int br
sh int fa0/1
sh int fa0/17
sh vlan br
Here is everything you asked for.
Show ip int br
Interface             IP-Address     OK? Method Status               Protocol
Vlan1                 192.168.1.223   YES NVRAM up                   up
Vlan3                 192.168.3.1     YES NVRAM up                   up
FastEthernet0/1       unassigned     YES unset up                   up
FastEthernet0/2       unassigned     YES unset down                 down
FastEthernet0/3       unassigned     YES unset down                 down
FastEthernet0/4       unassigned     YES unset down                 down
FastEthernet0/5       unassigned     YES unset down                 down
FastEthernet0/6       unassigned     YES unset down                 down
FastEthernet0/7       unassigned     YES unset down                 down
FastEthernet0/8       unassigned     YES unset down                 down
FastEthernet0/9       unassigned     YES unset down                 down
FastEthernet0/10       unassigned     YES unset down                 down
FastEthernet0/11       unassigned     YES unset down                 down
FastEthernet0/12       unassigned     YES unset down                 down
FastEthernet0/13       unassigned     YES unset down                 down
FastEthernet0/14       unassigned     YES unset down                 down
FastEthernet0/15       unassigned     YES unset down                 down
FastEthernet0/16       unassigned     YES unset down                 down
FastEthernet0/17       unassigned     YES unset up                   up
FastEthernet0/18       unassigned     YES unset down                 down
FastEthernet0/19       unassigned     YES unset down                 down
FastEthernet0/20       unassigned     YES unset down                 down
FastEthernet0/21       unassigned     YES unset down                 down
FastEthernet0/22       unassigned     YES unset down                 down
FastEthernet0/23       unassigned     YES unset down                 down
FastEthernet0/24       unassigned     YES unset down                 down
FastEthernet0/25       unassigned     YES unset down                 down
FastEthernet0/26       unassigned     YES unset down                 down
FastEthernet0/27       unassigned     YES unset down                 down
FastEthernet0/28       unassigned     YES unset down                 down
FastEthernet0/29       unassigned     YES unset down                 down
FastEthernet0/30       unassigned     YES unset down                 down
FastEthernet0/31       unassigned     YES unset down                 down
FastEthernet0/32       unassigned     YES unset down                 down
FastEthernet0/33       unassigned     YES unset down                 down
FastEthernet0/34       unassigned     YES unset down                 down
FastEthernet0/35       unassigned     YES unset down                 down
FastEthernet0/36       unassigned     YES unset down                 down
FastEthernet0/37       unassigned     YES unset down                 down
FastEthernet0/38       unassigned     YES unset down                 down
FastEthernet0/39       unassigned     YES unset down                 down
FastEthernet0/40       unassigned     YES unset down                 down
FastEthernet0/41       unassigned     YES unset down                 down
FastEthernet0/42       unassigned     YES unset down                 down
FastEthernet0/43       unassigned     YES unset down                 down
FastEthernet0/44       unassigned     YES unset down                 down
FastEthernet0/45       unassigned     YES unset down                 down
FastEthernet0/46       unassigned     YES unset down                 down
FastEthernet0/47       unassigned     YES unset down                 down
FastEthernet0/48       unassigned     YES unset down                 down
GigabitEthernet0/1     unassigned     YES unset down                 down
GigabitEthernet0/2     unassigned     YES unset down                 down
Show int fa 0/1
FastEthernet0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0012.d9a1.e181 (bia 0012.d9a1.e181)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:07, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 1 packets/sec
     809 packets input, 161343 bytes, 0 no buffer
     Received 762 broadcasts (0 multicast)
     0 watchdog, 343 multicast, 0 pause input
     74 packets output, 8797 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Show int fa 0/17
FastEthernet0/17 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0012.d9a1.e191 (bia 0012.d9a1.e191)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Full-duplex, 10Mb/s, media type is 10/100BaseTX
Last input never, output 00:00:00, output hang never
     1 packets input, 64 bytes, 0 no buffer
     Received 0 broadcasts (0 multicast)
     0 watchdog, 0 multicast, 0 pause input
     157 packets output, 12260 bytes, 0 underruns
Show vlan br
VLAN Name                             Status   Ports
1   default                         active   Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                               Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                               Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                               Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                               Fa0/18, Fa0/19, Fa0/20, Fa0/21
                                               Fa0/22, Fa0/23, Fa0/24, Fa0/25
                                               Fa0/26, Fa0/27, Fa0/28, Fa0/29
                                               Fa0/30, Fa0/31, Fa0/32, Fa0/33
                                               Fa0/34, Fa0/35, Fa0/36, Fa0/37
                                               Fa0/38, Fa0/39, Fa0/40, Fa0/41
                                               Fa0/42, Fa0/43, Fa0/44, Fa0/45
                                                Fa0/46, Fa0/47, Fa0/48, Gi0/1
                                               Gi0/2
2   Server                           active
3   VOICE_VLAN                       active   Fa0/17
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                 act/unsup
1005 trnet-default                   act/unsup
Rahul Kukreja
Jay -
Rahul
Got it.  Makes perfect sense, to add the ip route and also setup the default gateway.  Thanks for all your help and guidance.  Really appreciate it.  Have a Happy New Year.
