Need help with internet connectivity
kakomaisa
hello
iam having Cisco router 2800.
what iam trying to do is connecting my router with GT784WNV modem from Verizon
this connection doesnot support PPPOE or PPPOA , The way iam connecting to Verizon is through static IP address on Modem side .
iam able to ping and trace from cisco router but when I tried to browse internet from any client I cannot
here is my configuration
Current configuration : 4686 bytes
! Last configuration change at 09:05:15 MST Fri Jan 16 2015
version 12.4
hostname XX
boot-start-marker
boot system flash:c2801-advsecurityk9-mz.124-24.T6.bin
boot-end-marker
logging message-counter syslog
logging buffered 32768
enable password XX
no aaa new-model
clock timezone MST -7
clock summer-time MDT recurring
clock calendar-valid
dot11 syslog
ip source-route
ip cef
archive
 log config
  hidekeys
class-map match-all PRIORITY
 match access-group name PRIORITY
policy-map PRIORITY
 class PRIORITY
    priority 1000
interface FastEthernet0/0
 ip address 10.2.1.1 255.255.255.0
 ip flow ingress
 ip flow egress
 duplex auto
 speed auto
Description connection to LAN
 service-policy output PRIORITY
interface FastEthernet0/1
 ip address 10.2.2.1 255.255.255.0
 duplex auto
 speed auto
Description connection to WIFI
interface FastEthernet0/1/0
 ip address 10.2.3.2 255.255.255.0
 duplex auto
 speed auto
Description connection to DSL
interface Serial0/3/0
 ip address 10.99.0.2 255.255.255.252
 encapsulation ppp
Description connection to PPP
router rip
 version 2
 network 10.0.0.0
 no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.2.3.1
ip route 4.2.2.2 255.255.255.255 10.2.3.1
ip route 10.3.1.0 255.255.255.0 10.99.0.1
ip route 10.3.2.0 255.255.255.0 10.99.0.1
ip route 10.3.3.0 255.255.255.0 10.99.0.1
ip route 10.9.1.0 255.255.255.0 10.99.0.1
ip route 10.9.2.0 255.255.255.0 10.99.0.1
ip route 10.9.3.0 255.255.255.0 10.99.0.1
ip route 10.13.1.0 255.255.255.0 10.99.0.1
ip route 10.13.2.0 255.255.255.0 10.99.0.1
ip route 10.13.3.0 255.255.255.0 10.99.0.1
ip route 10.13.4.0 255.255.255.0 10.99.0.1
ip route 10.17.1.0 255.255.255.0 10.99.0.1
ip route 10.18.1.0 255.255.255.0 10.99.0.1
ip route 10.90.0.0 255.255.0.0 10.99.0.1
ip route 10.90.41.0 255.255.255.0 10.99.0.1
ip route 10.99.0.6 255.255.255.255 10.99.0.1
ip route 10.99.0.16 255.255.255.252 10.99.0.1
ip route 10.99.0.18 255.255.255.255 10.99.0.1
ip route 10.99.0.32 255.255.255.252 10.99.0.1
ip route 10.99.0.34 255.255.255.255 10.99.0.1
no ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 10.2.1.10 2055
ip flow-export destination 10.17.1.66 2055
ip access-list extended PRIORITY
 permit ip any 155.55.131.0 0.0.0.252
 permit ip any 65.55.114.0 0.0.0.248
 permit ip any 65.55.123.0 0.0.0.240
 permit ip any 65.55.183.0 0.0.0.248
 permit ip any 64.4.19.0 0.0.0.255
access-list 1 permit 10.2.0.0 0.0.255.255
access-list 10 permit any
access-list 110 permit ip 10.2.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
snmp-server community public RO
control-plane
Any help will be appreciated
Correct, same principle 10.2.1.x needs to get nated on the Cisco or in your modem
something like
access-list 199 permit ip 10.2.1.0 0.0.0.255 any
ip nat inside source list 199 interface fa0/1/0 overload
int fa0/0
   ip nat inside
int fa0/1/0
   ip nat outiside
10 Replies 10
Chris Carlson
Level 4
Level 4
you need to translate your inside addresses using NAT.
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13770-1.html
Thank you chris for your reply
I have concern here .
why do I need to do natting on cisco router since all nats are done from my dsl modem
then your network interface that is connected to your modem is the only network your modem is nating.. it is not nating the rest of your networks.
ok
let me explain
as you can see I have fa 0/0 which is connected to our switch
f0/1 subnet for guest users and they use PPP to go out
f0/1/0 is going to be used by all users if they are going to internet
if they are going to data center then they will go through PPP
I hope it is clear
Usually the ISP modems only NAT the network of their LAN in this case 10.2.3.x/24 which is why you can ping and trace from the router, because your traffic is sourced with the ip 10.2.3.2
When you try to go to the internet from a PC it uses the IP 10.2.2.x/24 and it is probable that the modem is not doing NAT for that network
You have two options
1- NAT on the Cisco router as Chris suggested, that way all the 10.2.2.x/24 would appear as a 10.2.3.x address and get nated on the verizon modem
2- Check if your modem can do the NAT for the second network (10.2.2.x/24)
thank you Luis for your reply
but again I donnot care about 10.2.2.x since they are routed through PPP.
I care about 10.2.1.x
so do you mean I have to do ip nat inside for fa0/0
on interface f0/0 I add ip nat inside
on interface fa 0/1/0 I add ip nat outside
and it doesnot work
ip nat inside and ip nat outside just tell the router the interfaces that are going to be involved in the NAT process, you still need to create a rule to select which traffic is going to be nated. Something like the example above.
Here is a link with more information regarding NAT
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/15-mt/nat-15-mt-book/iadnat-addr-consv.html#GUID-8DF8A9A7-4FFF-4AA7-AA93-B3F8FB705C50
thank you very much Luis
it works
appreciate your help
something like
int fa0/0
   ip nat inside
int fa0/1/0
   ip nat outiside
