need help with NAT and ACL
npereira
See my config bellow.
I have a webserver directly connected to fa1/0 with an IP of 10.1.10.10 with xover cable.
fa0/0 is directly connected to the internet.
With the access list and NAT translations, no one from the internet (or connections originating from the same subnet as the fa0/0 ex: x.x.x.25) can connect to the webserver via x.x.x.253 or 254
What am I missing?
Code:
Building configuration...
Current configuration : 2571 bytes
version 12.4
hostname SIP-NA-PUBLIC
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxx
enable password xxxxxxxx
aaa new-model
aaa session-id common
resource policy
ip cef
ip domain name xxxxxx.com
ip name-server 206.191.0.141
ip name-server 206.191.0.210
username xxxxxx password 0 xxxxxxxx
interface FastEthernet0/0
ip address x.x.x.254 255.255.255.0 secondary
ip address x.x.x.253 255.255.255.0
ip access-group 100 in
ip nat outside
ip virtual-reassembly
speed 100
full-duplex
no mop enabled
interface FastEthernet1/0
ip address 10.1.10.1 255.255.255.0
ip access-group 101 out
ip nat inside
duplex auto
speed auto
interface FastEthernet1/1
ip address 10.1.11.1 255.255.255.0
duplex auto
speed auto
ip default-gateway x.x.x.1
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 x.x.x.1
ip nat source list 100 interface FastEthernet0/0 overload
ip nat inside source static tcp 10.1.10.10 80 x.x.x.253 80 extendable
ip nat inside source static tcp 10.1.10.10 5060 x.x.x.253 5060 extendable
ip nat inside source static tcp 10.1.10.11 80 x.x.x.254 80 extendable
ip nat inside source static tcp 10.1.10.11 5060 x.x.x.254 5060 extendable
access-list 100 permit tcp any x.x.x.0 0.0.0.255 established
access-list 100 permit tcp any x.x.x.0 0.0.0.255 eq 22
access-list 100 permit udp any x.x.x.0 0.0.0.255 eq tftp
access-list 100 permit tcp any x.x.x.0 0.0.0.255 eq www
access-list 100 permit tcp any x.x.x.0 0.0.0.255 eq 161
access-list 100 permit tcp any x.x.x.0 0.0.0.255 eq 162
access-list 100 permit udp any x.x.x.0 0.0.0.255 eq syslog
access-list 100 permit tcp any x.x.x.0 0.0.0.255 eq 5060
access-list 100 deny udp any any eq time
access-list 100 deny udp any any eq tacacs
access-list 100 deny udp any any eq bootps
access-list 100 deny tcp any any eq sunrpc
access-list 100 deny udp any any eq sunrpc
access-list 100 deny ip any any log
access-list 101 permit tcp any 10.1.10.0 0.0.0.255 eq www
access-list 101 permit tcp any 10.1.10.0 0.0.0.255 eq 5060
access-list 101 deny ip any any log
snmp-server community xxxxxx RW
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxxxx
login authentication xxxxxxxx
transport input all
transport output all
end
amit-singh
Level 8
Level 8
Try removing the access-group 101 from Fa1/0 interface. And also try changing your static NAT statement to " ip nat inside source static 10.1.10.10 x.x.x.253" and see if that works.
HTH,
-amit singh
i can't remove my ip nat statement and replace it with what you suggested as then, it shuts off my ssh session to the fa0/0
npereira
I got it working,
the problem is the device connected to fa1/0 has 1 ETH ports, one is active, the other one is standby and I wanst connected to the correct one.
