Need help with NAT
ja raju
Hi guys,
Need some help on how to perform NAT on Router A (shown in the attached diagram).
I have a vpn tunnel between two site, and I need to access a device in 172.16.1.x from 172.24.103.x segment. The problem is I have another 172.16.1.x on the LAN. So I'd like to configure static NAT on Router A, lets say 192.168.145.50 -> 172.16.1.50.
I configured this on Router A but it's not working:
ip nat inside source static 192.168.145.54 172.16.2.54
ip nat inside source static 172.16.2.54 192.168.145.54
How can I make this work?
Thanks in advance.
HI,
Could you please remove the following NAT entry which is not needed:
no ip nat inside source static 192.168.145.54 172.16.1.54
When you are sending some traffic from 172.16.1.54 to 172.64.103.x, run a debug ip nat on the router to see if the translation really occurs. If it's the case then check those packets are well encrypted.
Laurent.
7 Replies 7
Laurent Aubert
Did you try to configure the NAT on the FW ? I think it makes more sense from a design perspective.
Laurent.
Thanks Laurent.
I do not have access to that firewall. Is it not possible to make the NAT work from Router A?
Yes it should work.
Can you post the config of Router A ?
Laurent.
Hi Laurent,
This is the config on the router:
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
no service dhcp
hostname Router
boot-start-marker
boot-end-marker
logging buffered 4096
no logging console
enable secret 5
no aaa new-model
clock timezone WST 8
no ipv6 cef
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
username admin privilege 15 secret 5
redundancy
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key address
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map VPN-TUNNEL 10 ipsec-isakmp
set peer
set transform-set ESP-3DES-SHA
set pfs group1
match address ACL-VPN
interface GigabitEthernet0/0
description Interface facing Internal network -- Inside
ip address 192.168.145.5 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
description Interface facing Internet -- Outside
ip address 255.255.255.240
ip nat outside
duplex auto
speed auto
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static 172.16.1.54 192.168.145.54
ip route 0.0.0.0 0.0.0.0
ip route 172.16.0.0 255.240.0.0 192.168.145.1
ip route 172.24.103.0 255.255.255.0
ip access-list extended ACL-VPN
permit ip 192.168.145.0 0.0.0.255 172.24.103.0 0.0.0.255
permit ip 172.24.103.0 0.0.0.255 192.168.145.0 0.0.0.255
logging trap debugging
logging facility local5
no cdp run
control-plane
line con 0
exec-timeout 15 0
logging synchronous
line aux 0
exec-timeout 15 0
no exec
line vty 0 4
exec-timeout 30 0
logging synchronous
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
HI,
Laurent.
Thanks. I'll try it out and get back here if there's any issue.
I got the NAT to work with the info you guys provided. I also had to get the clients to add firewall rules and routing to get the whole thing to work.
