Need help with packet tracer
Thepipe0
I can´t successfully ping or tracert between the computers on the network. I am new to this and dont understand what is wrong. I am assuming it has to do with the routers settings, since the computers under the same switch ping each other just fine. I am attaching the .pkt file for reference. Any help is appreciated.
Thanks in advance!
the IP addresses and interfaces on the Leon (top) router were switched, meaning the wrong IP addresses were assigned to the interfaces.
Check the attached revised file (saved in PT version 8, so you need to have that version installed in order to open the attachment)...
Thank you very much for your prompt response. I am unable to open the file. I do have version 8.0 however, i am still getting an uncompatible error for the file. I will reinstall and try again, and if not, i will fiddle much more with the config on that router. Thanks!!!
just in case, here are the working configs. That said, RIP does not really work well in Packet Tracer, unless it is a hard requirement, better use EIGRP or OSPF.
Leon#sh run
Building configuration...
Current configuration : 795 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Leon
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 192.100.3.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
description Link to Queretaro
ip address 192.168.2.1 255.255.255.0
interface Serial0/1/0
description Link to Puerto_Vallarta
interface Vlan1
no ip address
shutdown
router rip
version 2
network 192.100.3.0
network 192.168.1.0
network 192.168.2.0
no auto-summary
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Puerto_Vallarta#sh run
Current configuration : 846 bytes
version 12.4
hostname Puerto_Vallarta
no ip cef
no ipv6 cef
ip address 192.100.1.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
description Link to Leon
ip address 192.168.1.2 255.255.255.0
clock rate 2000000
ip address 192.168.3.1 255.255.255.0
clock rate 2000000
interface Vlan1
no ip address
shutdown
router rip
version 2
network 192.100.1.0
network 192.168.1.0
network 192.168.3.0
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Queretaro#sh run
Current configuration : 820 bytes
version 12.4
hostname Queretaro
no ip cef
no ipv6 cef
ip address 192.100.2.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 192.168.2.2 255.255.255.0
clock rate 2000000
ip address 192.168.3.2 255.255.255.0
interface Vlan1
no ip address
shutdown
router rip
version 2
network 192.100.2.0
network 192.168.2.0
network 192.168.3.0
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
