Need help with second WS-SUP720-3BXL (hot)
Adam Coombs
Hello I need help or advice
I have move 6509 core device from one network to another network
This 6509 had everything up and running no issue with anything, also to verify no issue did power off test and reload test before erasing the config.
I erase the old config from the 6509 device using this weblink
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2900-xl-series-switches/24328-156.html
I have IOS software, s72033-adventerprisek9_wan-mz.122-33.SXJ3.bin
After I erase config on the 6509 i was but in romon mode, I correct this with setting the boot location.
After I get the IOS load and confirm the config is erase.
When I do a show module
5    2  Supervisor Engine 720 (Active)
6    0  Unknown (Other)                        Unknown
I have pull the second sup out of the 6509 device while it is on and place it back in.
Lights flash then go solid green then change to all solid red.
Here is another command I issue
show bootvar
BOOT variable = disk0:s72033-adventerprisek9_wan-mz.122-33.SXJ3.bin,1;disk1:s72033-adventerprisek9_wan-mz.122-33.SXJ3.bin,1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby not ready to show bootvar
Please help
Muhammed Jobe
Adam
The second sup appears to be in rommon. Console into it and boot the same image running on the Active.
Sorry i forgot to update this
I console into the second supervisor
it was in rommon
i set the boot
then reload
it came up
