Need help with setting up Cisco 3550 to route to 1841 router
Aaron Polanco
Can someone help me with setting up a Cisco 3550 Layer 3 Switch to route to Cisco 1841 router.
13 Replies 13
Aaron Polanco
Also, I would like assitance with setting up layer 3 routing between Cisco 3550 switches.
I have two networks that I need to connect via Cisco 3550 layer 3 switches through their fastEthernet ports. the spoke networks are 10.3.0.0 255.255.0.0 and 10.1.0.0 255.255.0.0. The hub network is 10.2.0.0 255.255.0.0.
What would the first step be?
I will not be using routing protocols.
I plan to:
configure ip routing on the Cisco 3550 switch.
configure a no switchport with an IP Address on the Fastethernet interface leading to the Cisco 1841 router.
Configure default route leading to the Cisco 1841 router.
How would I connect the other two switches from different networks to the Cisco 3550 layer 3 device connected to the Cisco 1841 router?
This what I want to do, or need to do. Setup my Cisco 3550 layer devices to route between locations.
connect each access switch with a trunk port going to the core L3 switch,,configure the VLANS on the core then configure a VLAN interface for each VLAN in your network that needs communication.
Alain
hi,
what's your network topology looks like? could you share a brief diagram?
Simon Leigh
Hi there.
What are your requirements for this?
Any preference for routing protols, switch config, ip addressing and so forth.
The.Sorrow
To the OP:
Is there any particular reason as to why yu dont want to use RIP/EIGRP/OSPF?
