Need help with Site to Site VPN
Kevin Cummins
Hello.
I inherited this router and I am trying to setup a vpn tunnel on a virtual interface. (I dont want to apply it directly to the outside interface)
This is my first time to do this, so I am pretty sure I am doing the setup wrong. The other side of the tunnel will be setup by someone else, I just need to make sure my side is set correctly. Below is what I have so far for my "crypto map vyatta". Please let me know what I am doing wrong or what I am missing (ACLs, routes, etc)
Router#sh run
Building configuration...
Current configuration : 16761 bytes
! Last configuration change at 23:39:53 JST Thu May 16 2012 by
! NVRAM config last updated at 23:39:58 JST Thu May 16 2012 by
version 12.4
parser config cache interface
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
crypto isakmp key 12345 address 118.55.32.64
crypto isakmp keepalive 20 periodic
crypto ipsec transform-set vyattaset esp-aes esp-sha-hmac
crypto map vyatta 50 ipsec-isakmp
set peer 118.55.32.64
set transform-set vyattaset
set pfs group5
match address 101
interface FastEthernet0
  bandwidth 100000
no ip address
no ip redirects
no ip proxy-arp
ip flow ingress
ip virtual-reassembly max-reassemblies 64
load-interval 30
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
description Unused
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Virtual-Template101 type tunnel
ip unnumbered Dialer1
crypto map vyatta
interface Dialer1
  bandwidth 100000
ip address 223.159.226.82 255.255.255.248
ip access-group xxx in
ip access-group yyy out
no ip redirects
ip accounting output-packets
ip mtu 1454
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly max-fragments 64 max-reassemblies 512
encapsulation ppp
ip route-cache policy
ip tcp adjust-mss 1414
load-interval 30
dialer pool 1
no cdp enable
ppp chap refuse
ppp pap sent-username fake@mail.com password 7 11111111111111111111111111
router eigrp 300
redistribute static
network 10.0.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
ip route 10.0.0.0 255.0.0.0 Null0
ip route 172.16.0.0 255.240.0.0 Null0
ip route 192.168.0.0 255.255.0.0 Null0
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination 10.130.10.30 2055
ip flow-top-talkers
top 20
sort-by bytes
no ip http server
no ip http secure-server
ip nat translation timeout 600
ip nat inside source route-map NAT-RM interface Dialer1 overload
ip access-list extended xxx
permit tcp host 223.159.226.84 any eq smtp
permit tcp host 223.159.226.83 any eq smtp
permit tcp host 223.159.226.82 any eq smtp
deny   tcp any any eq smtp
permit ip any any
ip access-list extended yyy
remark Deny spoofing of internal network
deny   ip 223.159.226.81 0.0.0.7 any log
remark Block reserved addresses
deny   ip 10.0.0.0 0.255.255.255 any log
deny   ip 172.16.0.0 0.15.255.255 any log
deny   ip 192.168.0.0 0.0.255.255 any log
remark Block bogus network (RFC3330 bogons)
deny   ip 0.0.0.0 0.255.255.255 any log
deny   ip 127.0.0.0 0.255.255.255 any log
deny   ip 169.254.0.0 0.0.255.255 any log
deny   ip 192.0.2.0 0.0.0.255 any log
deny   ip 198.18.0.0 0.1.255.255 any log
deny   ip 224.0.0.0 15.255.255.255 any log
deny   ip 240.0.0.0 15.255.255.255 any log
remark Deny traffic from bad host addresses, 0.x.x.x and 255.255.255.255
deny   ip host 0.0.0.0 any log
deny   ip host 255.255.255.255 any log
remark Deny traffic to subnet address and subnet broadcast address
deny   ip any 0.0.0.0 255.255.255.0 log
deny   ip any 0.0.0.255 255.255.255.0 log
remark Allow any established traffic
permit tcp any 219.106.249.72 0.0.0.7 established
remark Allow good ICMP, block bad ICMP
deny   icmp any any log fragments
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any ttl-exceeded
permit icmp any any port-unreachable
permit icmp any any administratively-prohibited
permit icmp any any host-unreachable
remark Deny and log all other traffic by protocol
deny   tcp any any log
deny   udp any any log
access-list 101 permit ip 10.130.10.0 0.0.0.255 10.70.35.0 0.0.0.255
access-list 101 permit ip 10.130.20.0 0.0.0.255 10.70.35.0 0.0.0.255
route-map NAT-RM permit 10
match ip address NAT-ACL
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
login authentication NO_AAA
line aux 0
line vty 0 3
exec-timeout 30 0
logging synchronous
login authentication LOCALAUTHEN
rotary 1
transport input ssh
line vty 4
access-class SSH_VTY_FILTER in
exec-timeout 30 0
logging synchronous
rotary 1
transport input ssh
process cpu threshold type interrupt rising 50 interval 60 falling 20 interval 60
ntp clock-period 17180521
end
28 Replies 28
nikalleyne
What is the reason for not wanting to apply the crypto map to the physical interface?
There is anoother tunnel that points to Dialer1 with a "tunnel source Dialer1" and a virtual template that points to the dialer 1 as well with a "ip unnumbered Dialer1" (not shown in the config above).
Just didnt want things to break if I put the crypto map directly on the interface.
Ok. I was able to get the tunnel up by directly applying it to the dialer interface, however, now i cannot get any traffic to go from the local 10.130.10.0/24 to the 10.70.35.0/24 on the other side of the tunnel.
Anything I'm missing?
is there a FW in between? perhaps thats blocking ESP packets which are needed for encrypting the data and sending. do a  " sh crypto ipsec sa peer "  and see if the encrypted packets and decrypted packets are infrementing or not incrementeing at al. you can post the output here so that we can help
Kishore
Here's the output:
sh crypto ipsec sa peer 118.55.32.64
interface: Dialer1
    Crypto map tag: vyatta, local addr 223.159.226.82
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.130.10.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (10.70.35.0/255.255.255.0/0/0)
   current_peer 118.55.32.64 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 223.159.226.82, remote crypto endpt.: 118.55.32.64
     path mtu 1454, ip mtu 1454, ip mtu idb Dialer1
     current outbound spi: 0x400D50A6(1074614438)
     inbound esp sas:
      spi: 0xA9C4F961(2848258401)
        transform: esp-aes esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 137, flow_id: Motorola SEC 2.0:137, crypto map: vyatta
        sa timing: remaining key lifetime (k/sec): (4389324/2263)
        IV size: 16 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 138, flow_id: Motorola SEC 2.0:138, crypto map: vyatta
        sa timing: remaining key lifetime (k/sec): (4389324/2260)
        IV size: 16 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
interface: Virtual-Access3
     inbound esp sas:
        IV size: 16 bytes
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        sa timing: remaining key lifetime (k/sec): (4389324/2259)
        IV size: 16 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
Also tried adjusting the access lists. Still no go.
What am I missing? Do I need to do a reload on the router? NAT issue?
Can you provide output of sh crypto isakmp sa.
Regards.
Alain
wan01#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst                      src                      state               conn-id slot status
223.159.226.82    118.55.32.64        QM_IDLE           2049    0 ACTIVE
222.229.218.113   219.106.249.73    QM_IDLE           2044    0 ACTIVE
210.172.23.97      219.106.249.73    QM_IDLE           2048    0 ACTIVE
223.159.226.82    222.230.136.1      QM_IDLE           2045    0 ACTIVE
223.159.226.82    203.186.221.54    QM_IDLE           2042    0 ACTIVE
223.159.226.82    116.247.83.242    QM_IDLE           2043    0 ACTIVE
IPv6 Crypto ISAKMP SA
wan01#
Check the access-list at your peer router. The access-lists has to be identical at both sites.
Ok. I will check the other side again. I just wanted to make sure that there was nothing wrong with the config on this side. I just didn't no what to think when the traffic from this side of the tunnel got stopped at the routers internal ip address with a Destination Unreachable error.
I will report back in about an hour. Don't go anywhere.  ^_^
Kevin,
What we need to make sure is thatt traffic doesnt get NATed.  I believe  your traffic is getting NATed. You  need to write an acl which doesnt  NAT when traffic from the 10.130.10 and 10.130.20 subnets. In your natnoverload statement you have NAT-ACL defined. I couldnt see it.  In that ACL you need to deny the traffic originatibg frim the subnets above.  Do you see what i am trying to say?
Also where is your lan interface? I mean which interface are  you using for yiur lan. There should be an ip addres on it and also ip nat inside configured.
Sorry for the typos. I am writing this from samsung galaxy tab and the keypad is not helping me.:-)
Hth
Kishore
Here is the NAT-ACL:
ip access-list extended NAT-ACL
remark deny static NAT entries
deny   ip host 10.130.0.10 any
deny   ip host 10.130.10.20 any
deny   ip host 10.130.10.23 any
deny   ip host 10.130.10.24 any
deny   ip 10.130.10.0 0.0.0.255 10.70.35.0 0.0.0.255
permit ip 10.130.0.0 0.0.255.255 any
interface Vlan100
description to Core (10.130.100.0/24)
ip address 10.130.100.3 255.255.255.0
no ip redirects
ip flow ingress
ip flow egress
ip nat inside
load-interval 30
standby 2 ip 10.130.100.1
standby 2 priority 110
standby 2 preempt delay minimum 60
Hello Kevin
The LAN interface (Vlan100) belongs to different subnet. You said your LAN subnet is 10.130.10.0/24 & 10.130.20.0/24.
In summary, the config is as shown below. Excluded Crypto-Map as it appears to be fine.
LAN Interface
ip address 10.130.10.0 255.255.255.0
ip nat inside
WAN Interface (In your case -> Dialer Interface)
ip nat outside
ip nat inside source list 100 interface dialer 1 overload
access-list 100 deny ip 10.130.10.0 0.0.0.255 10.70.35.0 0.0.0.255
access-list 100 permit ip 10.130.10.0 0.0.0.255 any
Below are all the other interfaces on my internet facing router (and core switch).
Im guessing I will need to make the tunnel to point to 10.130.100.3 then? (Since the 10.130.10/0 subnet is configured from the core switch)?
Sorry, this is a bit confusing for me too.
CoreSW
interface Vlan10
description SERVER-LAN-10.130.10.0/24
ip address 10.130.10.10 255.255.255.0
ip pim dense-mode
ip policy route-map POLICY-ROUTE
interface Vlan20
description DATA-LAN-10.130.20.0/24
ip address 10.130.20.10 255.255.255.0
ip helper-address 10.130.10.20
ip helper-address 10.130.10.22
router eigrp 300
redistribute static route-map STATIC->EIGRP
passive-interface default
no passive-interface Vlan100
no passive-interface GigabitEthernet1/0/4
no passive-interface GigabitEthernet2/0/4
network 10.130.0.2 0.0.0.0
network 10.130.0.6 0.0.0.0
network 10.130.1.1 0.0.0.0
network 10.130.8.10 0.0.0.0
network 10.130.10.10 0.0.0.0
network 10.130.20.10 0.0.0.0
network 10.130.35.1 0.0.0.0
network 10.130.35.33 0.0.0.0
network 10.130.40.10 0.0.0.0
network 10.130.70.0 0.0.0.0
network 10.130.100.10 0.0.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.130.100.1 name DEFAULT-HSRP-GATEWAY
Internet Router
interface Tunnel500
description DMVPN Hub - Tokyo
bandwidth 100000
ip address 10.150.0.1 255.255.255.0
no ip redirects
ip mtu 1370
ip flow ingress
ip hello-interval eigrp 300 15
ip hold-time eigrp 300 45
no ip next-hop-self eigrp 300
ip nhrp authentication sgdmvpn
ip nhrp map multicast dynamic
ip nhrp map 10.150.0.10 222.229.218.113
ip nhrp map multicast 222.229.218.113
ip nhrp network-id 550
ip nhrp holdtime 600
ip route-cache same-interface
ip tcp adjust-mss 1330
no ip split-horizon eigrp 300
ip summary-address eigrp 300 10.130.0.0 255.255.0.0 5
load-interval 30
qos pre-classify
tunnel mode gre multipoint
tunnel key 55000
tunnel path-mtu-discovery
tunnel protection ipsec profile DMVPN-IPSEC-PROFILE
interface Tunnel600
ip address 10.160.0.1 255.255.255.0
tunnel destination 119.27.35.97
interface Loopback0
ip address 10.130.1.1 255.255.255.255
bandwidth 100000
no ip address
no ip redirects
no ip proxy-arp
ip flow ingress
load-interval 30
duplex auto
speed auto
no cdp enable
description Unused
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
description to sgtkycoresw01 G1/0/1
switchport access vlan 100
load-interval 30
interface FastEthernet3
description to sgtkycoresw01 G2/0/1
load-interval 30
interface FastEthernet4
description to sgtkyfw01 Fa0/0
switchport access vlan 101
load-interval 30
interface FastEthernet5
description Unused
load-interval 30
interface FastEthernet6
description Unused
load-interval 30
interface FastEthernet7
description Unused
load-interval 30
interface FastEthernet8
description Unused
load-interval 30
interface FastEthernet9
description Unused
load-interval 30
interface Virtual-Template100 type tunnel
tunnel mode ipsec ipv4
tunnel protection ipsec profile DYNAMIC-IPSEC-PROFILE
