Need install guide C1117 router
Jaskaran1156011
I am trying to install c1117 router and soda on it ,I need help to install
ethanncollins93
To install a Cisco C1117 router and get SD-WAN (SDA/SD-WAN or “SODA”) running on it, you’ll need the correct IOS-XE image and the setup workflow that matches your license. The quickest path is to upgrade the router to the recommended IOS-XE release, enable the SD-WAN/SDA mode, and then push the configuration from Cisco DNA Center or vManage, depending on your deployment.
Cristian Matei
    Your requirement is a bit vague, as there could be multiple cases. See if this example applies to what you're looking for:
https://community.cisco.com/t5/sd-wan-and-cloud-networking/convert-isr1100-4g-from-viptela-vedge-os-20-9-8-to-ios-xe-17-9-8/m-p/5354786#M10739
Cristian.
