Need more option of track command in HSRP
gcsnetexpert
I have ethernet link from my two ISP and need to track both the ISP through Track command in HSRP configuration i need if i can track the reachability of any site via applying any rout map or something else and track it in my HSRP config.
Please assist if i can do so.
Giuseppe Larosa
Hello Anurag,
depending on IOS release HSRP can use object tracking so that you can define a ping test as the object to be tracked.
see for example:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_37_se/configuration/guide/swhsrp.html
Hope to help
Giuseppe
Hi Guiseppe,
Thanks very much.
Regrds,
Anurag
