need solution
sivared0001
Level 2
Level 2
1. Make end to end connectivity first. 2. Block the network for these site 1)Make sure that Site 4 will not advertise any network to Site 5 which it receiving from Site3 routers. 2) On site 5 , when we check routing table of R2 router, it don't have network of Site3 routers. ping 147.147.21.1 should be deny and ping 147.147.21.37 should be reachable.
12 Replies 12
are you try to config MPLS ? MP-BGP MPLS solve all issue you face
it give you reachability
it give you that BACKBONE is not accessible from any Site only traffic between Site is allow.
if it is mpls then, on what routers to configure mpls
Georg Pauwen
what instructions are you following ? What have you configured so far, and what is not working ?
i don't known anything about that i got topology i need to configure as in the text
 You need to redistribute route on R3 and R4.
And use route map to control the advertisement.
Hello
Site 3 and 5 have a discontiguous ospf area 0 domains so you to provide end to end connectivity you need to :
1 -R3 Mutually redistribute ospf/eigrp
2- R4 Redistribute ospf into eigrp but only advertise a default route into ospf area 0
The above should provide ene-end connectively between all sites but negate the advertisement of all external routes from sites 2/3/4 into site 5 (rtrs 5 & 2)
Kind Regards
Paul
got it everything except (advertise a default route into ospf area 0)
how to do that and on what router
the command is:
router ospf x
default-information originate always
What router you need to configure this on depends on where you want the traffic to exit...
Hello
isn't it that attached txt file? <  rtr4 ?
Kind Regards
Paul
Meesi Meck
Community Member
Configuration on GNS3 software
Meesi Meck
Community Member
Need Configuration commands for GNS3 software
