Need some help in regards to policy shaping
Joshipiyus81
We are encountering skype issues, like degradation in voice calls in one of the UK sites  when users call from UK to US.The pipe size is 50mb.  Our ISP has categorized our traffic as well and assigned 10mb in service plane for voice, 1.5 mb for vid, 128kb for critical data n so on. when we posted our question to them they replied below:
"The session between x.x.x.x and x.x.x.x seems off to me. Usually you won't see voice traffic that is spiky like this. Especially only inbound. It is not showing that it it's over the 10 Mbps allocated but I have seen something like this before where there are small spikes of traffic like this and it turns out to be much higher utilization than what the portal can show. Basically the traffic is micro bursting.
Can you check these IP's to make sure they are supposed to be in the voice plane? It could be that these IP's are in the wrong queue and thus causing drops in the voice queue. x.x.x.x  are skype servers"
We have 50mb pipe and have below QOS policy + silver peak connected to WAN router for WAN optimization. I  didnt see any drops in voice class which will indicate the voice class is over utilized.
class-map match-any CLASS-QOS-EIGRP
match access-group name QOS-EIGRP
class-map match-any CLASS-QOS-VIDEO
match access-group name QOS-CONFERENCE-SOURCES
class-map match-any CLASS-QOS-VOICE
match access-group name QOS-VOICE-SOURCES
policy-map POLICY-QOS-01
class CLASS-QOS-VOICE
priority percent 20
class CLASS-QOS-VIDEO
priority percent 50
class CLASS-QOS-EIGRP
priority 1000
policy-map POLICY-AVPN-20Mbps ==== not applied anywhere
class class-default
shape average 19000000
service-policy POLICY-QOS-01
policy-map POLICY-AVPN-50Mbps ====> currently in use on WAN interface
class class-default
shape average 49000000
Service-policy output: POLICY-AVPN-50Mbps
Class-map: class-default (match-any)
346130523 packets, 171528610486 bytes
30 second offered rate 1177000 bps, drop rate 0000 bps
Match: any
Queueing
queue limit 203 packets
(queue depth/total drops/no-buffer drops) 0/15300/0
(pkts output/bytes output) 346106759/171501197792
shape (average) cir 49000000, bc 196000, be 196000
target shape rate 49000000
Service-policy : POLICY-QOS-01
queue stats for all priority classes:
Queueing
queue limit 512 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 49669740/11914669856
Class-map: CLASS-QOS-VOICE (match-any)
44565838 packets, 9358494427 bytes
30 second offered rate 25000 bps, drop rate 0000 bps
Match: access-group name QOS-VOICE-SOURCES
296460783 packets, 159613940630 bytes
30 second offered rate 1142000 bps, drop rate 0000 bps
Match: any
(pkts output/bytes output) 296437019/159586527936
Mostly i see output drops that will pertain to def class traffic. is QOS policy has something to do with it
9 Replies 9
--> Our ISP has categorized our traffic as well and assigned 10mb in service plane for voice, 1.5 mb for vid, 128kb for critical data
What is your ISP matching on ? What are YOUR classes matching on ? It looks like you are matching on IP traffic, not on DSCP or EF. Post the full config of your device (and what device it is, since QoS is very platform specific)...
Thanks for the reply, please see below acess list for voice class
#sh access-lists QOS-VOICE-SOURCES
Extended IP access list QOS-VOICE-SOURCES
10 permit ip any any dscp ef
sh access-lists QOS-EIGRP
Extended IP access list QOS-EIGRP
10 permit ip any any dscp cs6
sh access-lists QOS-CONFERENCE-SOURCES
Extended IP access list QOS-CONFERENCE-SOURCES
10 permit ip any any dscp af41
20 permit tcp host x.x.x.x any eq 1720
30 permit tcp host x.x.x.x any range 3230 3235
40 permit udp host x.x.x.x any eq 1719
50 permit udp host x.x.x.x any range 3230 3280
This is Cisco cisco ISR4331 IOS XE  Version 03.16.04b.S
Hello
As your not incurring any specific BW utilization what are you actually matching on in the access -lists related to the class-maps?
I see in your child policy, the class-maps are LLQ which will have a default queuing of FIFO, but also is your class-default.
You could apply some fair queuing here to avoid any possible random drops of traffic that's isn't classified or negate higher traffic flows possibility staving out the smaller traffic flows
class class-default
fair queue
Kind Regards
Paul
Hello Paul,
Thanks for the reply please see below output of matching traffic via ACl
#sh access-lists QOS-EIGRP
#sh access-lists QOS-CONFERENCE-SOURCES
20 permit tcp host X any eq 1720
30 permit tcp host X any range 3230 3235
40 permit udp host X any eq 1719
50 permit udp host X any range 3230 3280
#sh access-lists CLASS-QOS-VOICE
So Paul the original config is as below: class class-default
 You want me to replace the above with below config.
class class-default
fair queue
Is shaping affecting the current traffic rate for voice. Do i need to remove shaping or fair queue will work with shaping into effect.
Fiar queue is actually a good thing to configure
Hello
You can apply the fair queuing to your existing shaping configuration.
priority percent 20
priority percent 50
priority 1000
class class-default
fair queue
As for your voip/video traffic i dont see a ports specific to RTP (udp 16384 32767) try applying the below
IP access list Extended QOS-CONFERENCE-SOURCES
60 permit udp host X any range 16384 32767
Kind Regards
Paul
Thanks a lot Paul for your reply we are majorly facing issues in skype conf calls when users in Dublin are trying to reach someone in US the quality of skype calls deteriorate.
You can apply the fair queuing to your existing shaping configuration ==> so the shaping config will remain as it is with no changes
class class-default
fair queue
Joseph W. Doherty
"Our ISP has categorized our traffic as well and assigned 10mb in service plane for voice, 1.5 mb for vid, 128kb for critical data n so on."
"class CLASS-QOS-VOICE
priority percent 20
priority percent 50
priority 1000"
I would check what's noted in red, above.
BTW, Cisco recommends not assigning more than 33% to LLQ (which, also BTW, is the aggregate of all priority classes).
What kind of "pipe" is this?  I.e. your ISP (an Internet Service Provider?) has set aside bandwidth and/or priority for different classes?
Why are you shaping at 49 Mbps?
Where is you WAN optimizer appliance in the topology?
This is Gig Link and our WAN optimizer is connected via the WAN router, so the traffic passes via WAN optimizer. Our shaping policy is set the same for other locations which has 50mb pipe as well. and the priority % is same for voice and video there as well.
Skype works fine there and no issues observed for those locations but the issues observed only in this location.
As to it working at other locations, and not just one, often that's because there's often some traffic difference at that one location (versus others), but without more information (like when I asked about topology, knowing whether the optimizer is upstream or downstream of the WAN router is rather important, just being connected to it doesn't tell me which), cannot really say what's might be causing your issue.
