Bookmark
Subscribe
1990
Need suitable replacement for 7204VXR border router
spfister336
Level 2
Level 2
We have a 7204VXR router acting as our border router doing two BGP sessions with our upstream provider (getting default route for Internet, small routing table for Internet2, advertising /21 subnet). We are looking for a replacement  that will support up to 10GE speeds. What is the best option for this? From the Cisco site, it looks like we should be looking at the ASR1002, is this correct?
5 Replies 5
Hi spfister336, The direct replacement for the Cisco 7200 series is the ASR series that you looked into here is a link on the EOL notice for the 7200 series
http://www.cisco.com/c/en/us/products/collateral/routers/7200-series-routers/end_of_life_c51-681414.html
as for the exact model here is a comparison chart for the ASR Series.
http://www.cisco.com/c/en/us/products/routers/asr-1000-series-aggregation-services-routers/models-comparison.html
as you mentioned the ASR 1002 support 10GE as few other models please refer to them for the exact model that would suit your requirement.
bsiapco
spfister336
Have you find the best option for this? If your budget permits, go with the ASR because the Cisco 7200 are already end of life.
Let me know if you need further assistance.
Thanks!
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Or the ASR 1001-X.
Or the ASR 1001-X.
Joe,
I can't believe the two Cisco SALES contractor (posts below) doesn't even know what they are selling.  ROFL!
Leo Laohoo
I will disagree with the posts/recommendation by the two Cisco SALES people below.  They've just provided you with the WRONG INFORMATION & recommendation.
I will agree with what Joseph has to say.  ASR 1001-X is fully capable of supporting of up to 10 Gbps input AND output traffic (no encryption).
If you plan to go up to 20 Gbps in the future, then consider looking at the ASR 1002-X.
