Need to configure NAT on c3745 router
Topology: https://i.imgur.com/a1azOy0.jpg
R1#show run
Building configuration...
Current configuration : 1269 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
ip name-server 8.8.8.8
archive
log config
hidekeys
ip tcp synwait-time 5
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.16.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet1/0
ip address 192.168.1.121 255.255.255.0
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet1/0 overload
access-list 10 permit 0.0.0.0
no cdp log mismatch duplex
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Network config for the VM:
network:
version: 2
renderer: networkd
ethernets:
enp0s3:
addresses:
- 192.168.0.3/24
gateway4: 192.168.0.1
nameservers:
search: [mydomain, otherdomain]
addresses: [8.8.8.8, 8.8.4.4]
Wireshark capture: https://i.imgur.com/7zruy6a.jpg
Someone told me this on another forum yesterday:
> Does the "cloud" have a route back to 192.168.0.0/24? [...] If you didn't put it there, the answer is no. So that's your problem. The return traffic has no route to your VM.
I was reading https://networklessons.com/cisco/ccie-routing-switching/ip-nat-inside-source-vs-ip-nat-outside-source and wonder if I need to do...
R1(config)#ip nat inside source static 192.168.0.1 192.168.1.121
R1(config)#ip nat inside source static 172.16.0.1 192.168.1.121
Is that correct?
53 Replies 53
Here is a GNS3 VM, plugged right into the router, there isn't even a switch involved this time. I set its interface and default gateway to 10.0.1.1, and set the VM itself to 10.0.1.2, but still no joy.
 Pretty messy this...look you private message please.
I can't seem to add to my last post due to some forum bug (hitting return keeps duplicating the image instead of putting the cursor at the end) so starting a new reply.
I tried traceroute but it doesn't get any further than 172.16.1.1.
Hi there!
 My Lab is up and running.
PC1> ping www.google.com
www.google.com resolved to 142.250.218.196
84 bytes from 142.250.218.196 icmp_seq=1 ttl=127 time=30.502 ms
84 bytes from 142.250.218.196 icmp_seq=2 ttl=127 time=32.565 ms
84 bytes from 142.250.218.196 icmp_seq=3 ttl=127 time=30.828 ms
84 bytes from 142.250.218.196 icmp_seq=4 ttl=127 time=25.879 ms
84 bytes from 142.250.218.196 icmp_seq=5 ttl=127 time=32.264 ms
PC1>
It was much more simple then what all we discussed.  Let me know when you want to get back to it.
--> R1(config)#ip nat inside source static 192.168.0.1 192.168.2.121
R1(config)#ip nat inside source static 172.16.0.1 192.168.2.121
What do you want to accomplish ? 192.168.0.1 is the IP address of the FastEthernet0/0 interface. Where is 192.168.2.121 configured, which device is that ?
So basically, from what source IP address do you want to NAT to which destination IP address ?
This the other version I have of the router config, where I have set the inside and outside (it's a completely different GNS3 project):
R1#show run
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
archive
log config
hidekeys
ip nat inside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
I want my VMs to be able to access the web, which they can't right now. I've been trying to do it for over 3 weeks, it's amazingly difficult apparently!
that is the outside interface of my router.
From 192.168.0.1 and 172.16.0.1 to 192.168.1.121 (I think).
Edit: I don't know why I put `192.168.2.121`, I meant `192.168.1.121`. So I think maybe I need to do
Is that correct?
Hello
First of all think of NAT as a way of hiding networks you do not wish to advertise
So to NAT any of your internal networks to have reachability  to the “Outside” first they need to be reachable from your own NAT router, So make sure this is correct first
Now when you have reachability internally from your NAT rtr then you can begin with  your NAT
Your “wan” interface is the public facing interface that external networks can reach so this is where in most cases NAT translates internal addresses too however you use can use ANY IP address not just the one assigned to your wan interface it doesn’t even need to be assigned to the wan interface for it to work as long it’s publicly routable and it specifically owned by you so external networks can reach it.
so 192.168.2.x is a viable addressing to NAT with if you own it and as I said it’s reachable externally.
Lastly
Ip nat inside source static 192.168.0.1 192.168.2.121
isnt viable as they will conflict in the NAT table so if you want to use just the external ip address then static PAT would be more applicable
ip nat inside source static tcp 172.16.0.1 443 192.168.2.121 443
Ip nat inside source static tcp 192.168.0.1 80 192.168.2.121 80
or dynamic PAT
ip nat inside source list xxx interface xxx overload
Kind Regards
Paul
> or dynamic PAT
Yup, that's what I was trying to do.
ip nat inside source list 10 interface fa1/0 overload
Settings that I've entered appear to have vanished a couple of time, so I'm having to re-enter them.
Anyway, I re-added those static routes to my physical router:
Then I re-set the static route on the virtual router like this:
ip route 0.0.0.0 0.0.0.0 192.168.1.11
I don't know why it was set like this again??
Anyway, I put it back to .11, but that way I can't even ping 8.8.8.8 from the router, never mind from a VM.
It is only when I have the static route set on the router to .1 (which is my physical router) that I am at least able to ping 8.8.8.8 from the virtual router.
Anyway, no matter how I have things set, my VMs can never get any further than 192.168.0.1 or 172.16.0.1.
