need to enable Option 60 on the Cisco 6509 switch
Hi Guys,
We have Cisco 6509 switch, in which DHCP is enabled and now we have WDS(Windows Deployment server) that needs option 60 to be enabled on DHCP scope for deplyoing OS remotley to PC's. can anyone give me the sample configuration to enable the option 60.
Need that ASAP.
Naresh
nkarpysh
I guess this is for PXE boot?
When a Pre-boot Execution Environment (PXE) client boots, it must perform two actions: it
must obtain an IP address from a Dynamic Host Configuration Protocol (DHCP) server, and it
must locate a PXE boot server that will send it the appropriate files from which to boot.
So you will need to specify the PXE boot server using the option commands in the DHCP
configuration. Option 60 is for PXEClient and Option 43 is for a set of parameters
including the IP of the server.
option 60 ascii PXEClient
option 43 hex your_hex_string_goes_here
Here's the PXE specification:
http://www.pix.net/software/pxeboot/archive/pxespec.pdf
Here's a link from Intel (PXE creators) that references several vendors
http://www.intel.com/support/network/adapter/pro100/bootagent/30619.htm
This is a nicer link about how to create the binary string:
http://www.rembo.com/rembo/kbase/kb01102802.html
Since the DHCP and the PXE boot server are different machines and IPs, option 43 and 60
will be used, both option formats have to be provided by the software vendor.
Option 43 is documented as "vendor specific information", so the information contained in
it varies from one vendor to another.  If the option should contain "a set of IP
addresses" as well as "tcp port number 6301".  You need to know exactly how this
information is formatted.
An example is below. If you want your option 43 to contain info in the following order:
1) IP address 10.0.0.1
2) IP address 20.0.0.2
3) Port number 6301 (as a two byte value)
This would be, in hex 1) 0a000001 2)14000002 3)189D so, the command would be option 43 hex
0a.00.00.01.14.00.00.02.18.9D option
Here is a little example to make it clearer:
ip dhcp pool INTERESTING
    network 10.10.1.0 255.255.255.0
    bootfile Setup\English\Tools\emBOOT\i386\tool4.ldr
    default-router 10.10.1.1
    dns-server 10.0.0.2 10.0.0.3
    domain-name voxcom.corp
    netbios-name-server 10.0.0.2
    option 66 ascii "vox_training"
    option 60 ascii "PXEClient"
    option 43 hex 06:01:07:08:07:00:0f:01:0a:00:00:33:09:05:00:0f:02:52:42:0a:02:00:52:ff
Hope this helps,
Nik
HTH,
Niko
