06-15-2015 08:05 PM - edited 03-05-2019 01:40 AM
Looking for a basic firewall / ACL's that will deny any unsolicited inbound traffic but allow all devices on the inside to operate normally,
Basic working config:
Cisco_881W#sho run
Building configuration...
Current configuration : 2022 bytes
! Last configuration change at 06:26:51 UTC Tue Jun 16 2015
version 15.0
no service pad
hostname Cisco_881W
boot-start-marker
boot-end-marker
enable password <removed>
no aaa new-model
memory-size iomem 10
service-module wlan-ap 0 bootimage autonomous
ip source-route
ip dhcp excluded-address 10.20.30.1 10.20.30.99
ip dhcp excluded-address 10.20.30.201 10.20.30.254
ip dhcp pool myDHCPpool
import all
network 10.20.30.0 255.255.255.0
default-router 10.20.30.1
dns-server 99.99.99.53 99.99.99.153
ip cef
ip name-server 9.99.99.53
ip name-server 9.99.99.153
no ipv6 cef
archive
log config
hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
ipv6 address dhcp rapid-commit
ipv6 enable
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
interface Vlan1
ip address 10.20.30.1 255.255.255.0
ip nat inside
router rip
version 2
network 10.0.0.0
network 108.0.0.0
network 192.168.1.0
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 23 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 108.71.140.1
access-list 23 permit 10.20.30.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
password <removed>
login
scheduler max-task-time 5000
end
Solved! Go to Solution.
06-16-2015 06:24 AM
Hi there,
You already have an implict deny since you are not NAT'ing external traffic to your inside network (port-forwarding).
In its current configuration you should configre an ACL on your line vty to allow only access from inside networks:
! line vty 0 4 access-class 23 in !
cheers,
Seb.
06-16-2015 06:24 AM
Hi there,
cheers,
Seb.
06-16-2015 04:06 PM
Hi Seb,
Thanks for responding. I kinda thought that was the case, but I have been away for so long from router configurations and ACL's I couldn't recall for sure. It gets blurry real fast when you stop using it.
So if I need to start opening ports that will be when I need to make sure I keep things straight. We'll see if the games work this weekend :)
Thanks again!
