need to help about EHWIC-D-8ESG-P
adam_obayid
hey
please i need to help , i try to install modul EHWIC-D-8ESG-P in router cisco 3925 but this card is not detected .
cordialy
is your router a 3925E ? The 3925 (without the E) does not support your card. If you have a 3925E, you need IOS version 15.1(2)T IP Base as a minimum.
http://www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c07_563807.pdf
http://www.cisco.com/c/en/us/products/routers/3900-series-integrated-services-routers-isr/series-comparison.html
5 Replies 5
please i need to help , i have the router 3925E , i have the problem in card not detected
EHWIC-D-8ESG-P
Adam
are you running IOS 15.1(2)T IP Base at a minimum ?
Console into the router and post the entire boot-up process.  We would like to see the error messages as they appear.
adam_obayid
my router is 3925E
