IPSec VPN Inbound - Zone-Based Firewall Issues
satnikn0036
Hello guys / gals,
I have been struggling with this issue for a few weeks now. I have single 3845 router at the internet edge, with clients directly behind it. The goal is that I have a working L2TP (IPSec) VPN concentrator on the LAN (inside security zone). Because I have to use PAT on the outside interface, technically the traffic flows from the OUTSIDE to the SELF zone, instead of outside-inside (I have to point the clients at my public IP address).
With this, I had been using pass to allow UDP 500, 4500, and ESP traffic). This was not allowing return traffic, so I have edited it to inspect from outside to self. The problem is that the return traffic is going over the Inside-Outside table.
I have already created static NAT entries and I have verified that they work by temporarily removing the firewall. In that case, I noticed that the VPN works. Filtered NAT Table is below (not during removal of firewall).
Family-Router#sh ip nat translations
esp 66.188.238.17:0 10.0.1.254:0 --- ---
udp 66.188.238.17:500 10.0.1.254:500 --- --
udp 66.188.238.17:500 10.0.1.254:500 --- ---
udp 66.188.238.17:4500 10.0.1.254:4500 --- --
Is anyone able to point me in the right direction in regards to allowing the UDP 500, 4500 and ESP traffic inside and back out?
The whole topology is below, showing the router and the Z1 VPN Concentrator behind it on the INSIDE.
When I first created this, i had set it up with CCP. Since then, I have made changes via the CLI since I have learned this feature. Hence the weird naming scheme.
I almost think it is time to scrap the entire firewall config from CCP and rebuild it. I would like to see if we can fix it. I think understanding what needs to be done here might help me understand the concept I am missing here.
I have already researched with this link ZBF Link, but I am still missing something here. Any help is greatly appreciated.
Zone-pair setup:
Family-Router#sh zone-pair security
Zone-pair name ccp-zp-self-out
 Source-Zone self Destination-Zone out-zone
 service-policy ccp-permit-icmpreply
Zone-pair name ccp-zp-in-out
 Source-Zone in-zone Destination-Zone out-zone
 service-policy ccp-inspect
Zone-pair name ccp-zp-out-self
 Source-Zone out-zone Destination-Zone self
Firewall config:
class-map type inspect match-any SDM_DHCP_CLIENT_PT
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-all VPNInbound
description allow VPN traffic from inet inbound
match access-group name VPNAllow
class-map type inspect match-any DHCP
match protocol bootpc
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any LOGIN
match protocol radius
match protocol ssh
match protocol telnet
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any VPN
description VPN
class-map type inspect match-any NTP
match protocol ntp
class-map type inspect match-all ccp-cls-ccp-permit-2
match class-map NTP
match access-group name NTP
class-map type inspect match-all ccp-cls-ccp-permit-1
match class-map DHCP
match access-group name DHCP
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any https
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-any dns
match protocol dns
match protocol dnsix
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
pass
class type inspect ccp-icmp-access
inspect
class type inspect VPN
inspect
class class-default
pass
policy-map type inspect ccp-inspect
class type inspect dns
inspect
pass
class type inspect LOGIN
inspect
class type inspect ccp-protocol-http
inspect
class type inspect https
inspect
class type inspect ccp-insp-traffic
inspect
class type inspect ccp-sip-inspect
inspect
class type inspect ccp-h323-inspect
inspect
class type inspect ccp-h323annexe-inspect
inspect
class type inspect ccp-h225ras-inspect
inspect
class type inspect ccp-h323nxg-inspect
inspect
class type inspect ccp-skinny-inspect
inspect
class type inspect VPNInbound
pass
class class-default
drop
policy-map type inspect VPN
description WAN to self-router
class type inspect ccp-cls-ccp-permit-1
pass
class type inspect ccp-cls-ccp-permit-2
pass
class type inspect SDM_DHCP_CLIENT_PT
pass
inspect
class class-default
drop
Family-Router#sh ip access-lists
Standard IP access list LOGIN
10 permit 10.0.0.0, wildcard bits 0.255.255.255 (2431120 matches)
20 permit 172.16.0.0, wildcard bits 0.0.0.255 (76 matches)
Extended IP access list 101
10 permit udp any eq bootps any eq bootpc
Extended IP access list DHCP
10 permit ip any any (47697 matches)
Extended IP access list Guest-Lockdown
10 permit ip any host 10.0.2.3
20 permit ip any host 10.0.1.4
30 permit ip any host 10.0.3.2
40 deny tcp any host 10.0.4.1 eq 22
50 deny ip any 10.0.1.0 0.0.0.255 (13 matches)
60 deny ip any 10.0.2.0 0.0.0.255
70 deny ip any 10.0.3.0 0.0.0.255
80 permit ip any any (11922 matches)
Extended IP access list NTP
10 permit ip any any (593 matches)
Extended IP access list VPNAllow
10 permit udp any any eq isakmp non500-isakmp
20 permit esp any any
0 Replies 0
