Need to help on CSR1000v configuration on open stack
aathi
Hi Team,
I have deployed CISCO CSR1000v on Open stack cloud in that i am having 2 interfaces in that i am able to ping the one .interface ip from outside not from other interface ip from outside.
giga1=192.168.100.18 and giga2-10.205.59.20
in that i am able to ping 100.18 and not able to ping 59 20 as configured on same router.Kindly help to reach the same.
Not able to activate the virtual service as well.as the virtual service list is showing activation failed.
Athi
I am not an OpenStack guru, but as I understand it, you can actually only manage, and reach, the CSR1000v through the management interface, which is GigabitEthernet1.
That said, can you post the running configuration, as well as a couple of screenshots that shows where the activation fails ?
Thanks for the update.Please find the attached configuration. Kindly check and help me on the same.
Do we need to create port group to access the VM which is directly connected to the CSR router.
Athi
what happens when you activate ? What message do you get ?
interface GigabitEthernet3
ip address 10.205.58.228 255.255.254.0
interface VirtualPortGroup0
ip unnumbered GigabitEthernet3
virtual-service csr_mgmt
vnic gateway VirtualPortGroup0
guest ip address 10.205.58.228
activate
ip route 10.205.58.228 255.255.255.255 VirtualPortGroup0
onep
service set vty
HI,
Please find the attached error message.I am not able to ping the VM directly connected to the CSR router .Do we need to create any port group .Kindly assist on this.
Athi
