Need to prefer a default route over another - based on source IP
rwharris13
Hello, I'm looking for some direction, if possible, on what I beleive needs to be some PBR done to create the following scenario:
2 ISP's connected to a 4507, both with seperate public IP blocks. Based on some source IP addresses on the LAN they would either use ISP-A or ISB-B's connection based on what I define.
cadet alain
hi,
yes you're right to implement source-based routing you need PBR. what do you want to know exactly?
regards.
alain
Unfortunately I have not implemented it before so I was really just looking for some help with a config or pointed to some documentation with examples. Not finding what I need through google searches, might be from not using the correct terminology. Thanks.
Here is useful link
https://supportforums.cisco.com/docs/DOC-1634
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
