Need to remove Serial T1 Card from Router Config
mkminshew
I have recently made a WAN change from T1 to fiber and my Cisco 2600 series router no longer needs to connect over the Serial T1 card. The Serial connection also provided a few voice channels for the old phone system that are no longer needed.  I need to keep Main Cisco 2600 router in place because I have many network devices that use it as the gateway instead of my firewall.  I will not require the second subnet for Offsite Cisco 2600 anymore either.  Please help me with the commands that will be required to remove all instances of the Serial connection and Offsite Cisco 2600.  I have included the config of the Main Cisco 2600 below.
Main Cisco 2600 - LAN Interface - 192.168.47.10 (keeping)
Cisco Firewall - 192.168.47.100 (will remain)
Offsite Cisco 2600 - LAN Interface - 192.168.20.10  (no longer needed)
Main Cisco 2600 Config
User Access Verification
Password:
Main>enable
Password:
Main#show config
Using 2303 out of 29688 bytes
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Main
enable secret
enable password
ip subnet-zero
no ip domain-lookup
voice-port 1/0/0
input gain 5
output attenuation 5
connection plar 76
description connected to PBX
voice-port 1/0/1
input gain 5
connection plar 77
dial-peer voice 5 pots
destination-pattern 9
port 1/0/0
prefix 9
dial-peer voice 11 pots
destination-pattern 1.
port 1/0/0
prefix 1
dial-peer voice 12 pots
destination-pattern 2.
port 1/0/0
prefix 2
dial-peer voice 13 pots
destination-pattern 3.
port 1/0/0
prefix 3
dial-peer voice 14 pots
destination-pattern 4.
port 1/0/1
prefix 4
dial-peer voice 15 pots
destination-pattern 5.
port 1/0/1
prefix 5
dial-peer voice 16 pots
destination-pattern 6.
port 1/0/1
prefix 6
dial-peer voice 86 voip
destination-pattern 7.
session target ipv4:192.168.20.10
dial-peer voice 87 pots
destination-pattern 87
port 1/0/1
dial-peer voice 88 pots
destination-pattern 86
port 1/0/0
interface Ethernet0/0
description connected to EthernetLAN_1
ip address 192.168.47.10 255.255.255.0
no ip directed-broadcast
no keepalive
bridge-group 1
interface Serial0/0
description connected to Branch
bandwidth 1536
ip unnumbered Ethernet0/0
ip rtp reserve 16384 100 56
encapsulation ppp
ip rtp header-compression iphc-format
ip tcp header-compression iphc-format
no ip mroute-cache
fair-queue 64 256 1
service-module t1 clock source internal
service-module t1 remote-alarm-enable
bridge-group 1
router rip
version 2
network 192.168.47.0
no auto-summary
ip default-gateway 192.168.47.10
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.47.100
ip route 192.0.0.0 255.0.0.0 Ethernet0/0
bridge 1 protocol ieee
line con 0
exec-timeout 0 0
login
transport input none
line aux 0
line vty 0 4
password
login
no scheduler allocate
end
Main#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
       U - per-user static route, o - ODR
Gateway of last resort is 192.168.47.100 to network 0.0.0.0
C    192.168.47.0/24 is directly connected, Ethernet0/0
     192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C       192.168.20.10/32 is directly connected, Serial0/0
R       192.168.20.0/24 [120/1] via 192.168.20.10, 00:00:25, Serial0/0
S*   0.0.0.0/0 [1/0] via 192.168.47.100
S    192.0.0.0/8 is directly connected, Ethernet0/0
Hi Kevin,
conf t
default interface se0/0
no dial-peer voice number type
no port voice-port 1/0/0          !   please check if the no port command is available on your IOS
no port voice-port 1/0/1
end
wr
Alessio
