OPT_E_MAN
MajidShirzadeh
Hello all,
Does anyone has some info about OPT_E_MAN, I want to run from A to B with two 3750.
Thank you.
2 Accepted Solutions
John Blakley
It'll work fine. You'll probably want to route over the circuit. Otherwise, AT&T lines to charge you for Mac addresses coming across the circuit. Don't quote me but I believe they allow 32 before charging extra.
John
HTH, John *** Please rate all useful posts ***
the easiest way is to set up a routed port. Say you want to use g1/0/1 on both switches. You'll configure each port as a routed port (no switchport) and then put an ip address on it. You can use a /30 between the 2 switches. It depends on what else you're going to want to do with this circuit as to if you'll need a routing protocol or just static routes.
John Blakley
John
Thanks John, do you have any template config or web site for that, I never done that before.
Thank you.
