Need to upload IOS in 7206 Router
Hi Expert,
I need to upload IOS c7200-advipservicesk9-mz.124-15.T16.bin
in 7206 NPE 400 router , As per cisco recommendation router should have DRAM : 256 MB ; Flash : 64
I think my router contain only DRAM= 128 MB but not sure.
I am pasting output of my router Pl's help me how much DRAM & Flash it contains.
Router1#sh version
IOS (tm) 7200 Software (C7200-IK9S-M), Version 12.3(1a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 05-Jun-03 20:58 by dchih
Image text-base: 0x60008954, data-base: 0x61E0C000
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(1a), RELEASE SOFTWARE (fc1)
Router1 uptime is 8 years, 18 weeks, 5 days, 23 hours, 16 minutes
System image file is "disk0:c7200-ik9s-mz.123-1a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 7206VXR (NPE400) processor (revision A) with 114688K/16384K bytes of memor
y.
Processor board ID 30469821
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 4096KB L3 Cache
6 slot VXR midplane, Version 2.7
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
5 Serial network interface(s)
4 Channelized T1/PRI port(s)
125K bytes of non-volatile configuration memory.
47040K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
Router1#sh disk0
-#- --length-- -----date/time------ path
1     18539336 Oct 10 2003 21:33:50 c7200-ik9s-mz.123-1a.bin
29360128 bytes available (18546688 bytes used)
Router1#sh bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- -----date/time------ name
1   .. image        E2FAE3BA  694694   25  6637076 Dec 23 1916 19:45:43 c7200-kb
oot-mz.123-1a.bin
964972 bytes available (6637204 bytes used)
Router doesn't support sh flash
Surya
8 Replies 8
Reza Sharifi
Hi Surya,
You are correct.  You have only 128MB DRAM, and you don't have enough flash.
Hi Reza,
Thanks for update.
Can you please tell me how much Flash Size & how to calculate that Value.
You need to talk to your authorized Cisco reseller for the price of the DRAM.
Hi Leo,
I want to know how to calculate Flash size ( i.e in MB) not price.
cisco 7206VXR (NPE400) processor (revision A) with 114688K/16384K bytes of memory.
Add the two values above and factor by 1024.
satya mothukuri
Hi Surya,
What is the siz e of new ios. i think as of now u have .9 Mb.
this are some thing which may help u i guess.
rouer#sh run <-
check the boot system flash and boot loader image
router# sh ver <-
1. check the flash image name
2. check the memory size
3. check the flash size
Router# copy tftp disk2:c7200-ik9s-mz.123-16.bin
Router# copy tftp slavedisk2:c7200-ik9s-mz.123-16.bin
Router# copy tftp bootflash:c7200-kboot-mz.122-15.B.bin
Router# copy tftp slavebootflash:c7200-kboot-mz.122-15.B.bin
Router# configure terminal
Router(config)# no boot system flash disk2:old image.bin
Router(config)# boot system flash disk2:c7200-ik9s-mz.123-16.bin
Router(config)# no boot bootldr bootflash:old boot loader.bin
Router(config)# boot bootldr bootflash:c7200-kboot-mz.122-15.B.bin
Router# write mem
Router# copy running-config startup-config
Router# reload
Satya.M
Hi Stya,
Thanks for Update.
I have some queries,
1) as per cisco recommendation we required DRAM=256MB & Flash=64 MB
So could you tell me how much DRAM & Flash present in router.
I am able to find out DRAM size but not Flash.
2) If router have DRAM 128 & I uploaded the IOS which required DRAM of 256 MB , What would be the impact.
Surya.
8 mb internal flash and another 32 mb PCMCIA card.
