Nested QoS Scalability
jamessohotha
Hi Guys,
I was wondering whether QoS nesting can be used to provide multi-site QoS with minimal policy configuration.
I have a 7200 series router connected at the central site serving 50+ locations of varying bandwidth. What I was attempting to do was create some predefined parent policies and then nest that map in each child policy that relates to each site. Example:
policy-map 256k-site
class voice
bandwidth 64
policy-map site-1
service-policy 256k-site
policy-map site-2
Would this work by creating 2 seperate queues for each site based on the parent policy or would the 2 sites just end up sharing the software queue??
10 Replies 10
Joseph W. Doherty
You can use the same policy on multiple interfaces. If you using a later IOS, you can define policy bandwidths using percentages (except, I believe, for shaping/policing). What do you need to vary per remote site policy?
There in lies the problem. The presentation is one single frame relay interface otherwise yes I would definatly use bandwidth percent policies.
As it stands access lists are being used to identify the relevant remote site traffic which is associated with a class. A policy is then assigned under that class e.g.
ip access-list extended remote-office
permit ip any xxx.xxx.xxx.0 0.0.0.255
class-map match-any traffic-remote-office
match access-group name remote-office
class traffic-remote-office
shape average 512000
service-policy traffic-512
Yup, using embedded shapers does make a bit of a problem.
What I've done in a similar situation was have parent policies for the various bandwidths being used by different sites. E.g. one for 128, 256, 512, 1024, etc. Each of these parent policies would use the same child policy that used percentages.
One other possible difference was I used subinterfaces for each PVC, each with its own policy.
Another issue was LLQ not supporting percentages until 12.4 (or 12.3T?).
Pseudo config:
policy-map remote-384
shape average 384000
service policy remote-condition
policy-map remote-512
class-map realtime
match protocol voice
class-map gold
match protocol citrix
policy-map remote-condition
class realtime
priority percentage 50
class gold
bandwidth remaining percentage 60
interface serial 0
interface serial 0.23
pvc 23
service policy remote-384 out
interface serial 0.45
pvc 45
service policy remote-512 out
interface serial 0.81
pvc 81
I would definatley use percentage based policing on the PVC's... if I had any PVC's that is.
The problem is that the WAN connections actually run over a provider MPLS network with a single frame relay interface presentation with no PVC's.
Thats why im sort of trying to use simple access lists to identify the traffic rather than just applying the relevant policies to the PVC.
I am assuming that IOS is not going to treat my attempt at creating virtual queues in the same way as it would if I had multiple PVC's and attached the policy to each cicuit.
I guess the best way to explain what I am after is to ask whether anyone knows whether it's possible to have multiple software queues associated with one hardware interface without any PVC's or subinterfaces??
Ah, I understand.
Then you could do this.
Pseudo config:
ip access-list extended remote-office-1
ip access-list extended remote-office-2
ip access-list extended remote-office-#
class-map realtime
class-map gold
class-map match-any traffic-remote-office-1
class-map match-any traffic-remote-office-2
class-map match-any traffic-remote-office-#
class realtime
class gold
policy-map remotes
class match-any traffic-remote-office-1
class match-any traffic-remote-office-2
shape average 256000
class match-any traffic-remote-office-#
shape average #
interface serial 0
service policy remotes out
Thats exactly it Joseph! The question is will IOS look at this and say...
"ok i am going to create a different software queue for each remote site based on the remote-condition map"
or
"because this is a single interface i am going to share the remote-condition policy bandwidth between the relevant sites"
Bear in mind there are no PVC's so the circuit is "unaware" of the remote site bandwidth capabilities, as such I cannot use percentage based QoS.
Pseudo config:
ip access-list extended remote-office-3
class-map realtime
class-map gold
match access-group name remote-office-1
match access-group name remote-office-2
class-map match-any traffic-remote-office-3
match access-group name remote-office-3
match access-group name remote-office-#
policy-map remote-condition-256
class realtime
priority 128
class gold
bandwidth 64
policy-map remote-condition-512
class realtime
priority 256
class gold
bandwidth 128
policy-map remotes
service policy remote-condition-512
service policy remote-condition-256
class match-any traffic-remote-office-3
shape average #
service policy remote-condition-#
interface serial 0
Each class will have it's own queue.
Each class has a shaper which will limit bandwidth utilization to that class. (NB: the shaper seems to create a FQ, so you might not even need the subpolicy unless other prioritization is important to you.)
The subpolicy's bandwidth percentages, which really set ratios between the classes (within the subpolicy), should work.
In using similar policies, I recall noticing queues forming both within the parent's class shaper and the child's classes.
Good stuff, so long as each class gets its own queue im sold!
Thanks for your help Joseph
Hi James,
I've almost an identical scenario, a 7201 router connected to the MPLS cloud using its Ethernet port but with less number of sites.
I'm attaching a high level diagram so you'd have an idea about my case.
