overrun error
rana_beech
I am getting overrun error on my 1700 router interface. From Cisco site it seems that this is due to
"overrun - Number of times the serial receiver hardware was unable to hand received data to the hardware buffer because the input rate exceeded the receiver's ability to handle the data"
Can i solve the problem by changing the hold queue? currently the depth is 75. After I did a counter reset I have not got that, but I think I will get that once in a while. And I forgot to capture the screen for now, so cannot post the 'sho int' here.
thanks,
Arana
paolo bevilacqua
Which exact type of interfaces you have in the router ?
This is for serial interface (WIC-1T on 1721).
thanks,
Arana
Any help on this?
thanks,
Arana
