Netflow commands on a 4451
Steve Wood
I am trying to configure Netflow support on a new 4451 and cannot get the following commands to accept. Can someone advise me please.
Cisco IOS XE Software, Version 03.10.00.S - Extended Support Release
Cisco IOS Software, ISR4400 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.3(3)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 25-Jul-13 17:45 by mcpre
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appx             None             None             None
uc               None             None             None
security         None             None             None
ipbase           ipbasek9         Permanent        ipbasek9
(config-if)#ip route
(config-if)#ip route-c
(config-if)#ip route-cache ?
  cef             Enable Cisco Express Forwarding
  policy          Enable fast-switching policy cache for outgoing packets
  same-interface  Enable fast-switching on the same interface
  <cr>
Only command available
(config-if)#ip flo
(config-if)#ip flow ?
  monitor  Apply a Flow Monitor
I am experiencing the same issue.  How did you fix this?
Follow the Flexible NetFlow Configuration Guide to configure Flexible NetFlow:
http://www.cisco.com/en/US/docs/ios-xml/ios/fnetflow/configuration/xe-3s/fnf-xe-3s-book.html
