support stopped
Johannes Kingma
Cisco stopped support for the rv180. Not firmware update. Partly functional, and still bloody expensive. Cisco should be ashamed.
rockrobi
Good Morning,
I apologize for any inconvenience you have experienced. However, the RV180 is still supported by Cisco. You can find the newest firmware update here:
http://software.cisco.com/download/release.html?mdfid=284005904&softwareid=282465789&release=1.0.4.14
1.0.4.14 is the latest firmware update, released 15 April, 2014.
Further, there is a whole knowledge base with plenty of articles about the RV180.
Link here: http://www6.nohold.net/ciscosb/Loginr.aspx?pid=4&app=search&vw=1&login=1
If you type "RV180" into the search bar at the top of the page, you will find detailed support documents that are meant to assist you with any questions you might have.
If these documents do not answer your questions, please post your question in this forum (Cisco Small Business Support forum) and a Cisco representative will get back to you with a response as soon as possible.
Rocket :)
rockrobi
Good Morning,
Rocket :)
