Netflow entries with source/dest. ip address 0.0.0.0?
Hi J
Have you got any idea, what the entries in the following netflow printouts with the source/destination ip-address 0.0.0.0 mean?  We can see them both on the CE- and PE-Routers and we do not use any tunnels/TE on the appropriate interfaces?
CE-028  àc6500
 netflow activated on Gi1/2 (vrf lite to PE-028)
PE-028 à c7600
Netflow activated on Gi2/0/0 (to MPLS-Net)
                                                Gi2/0/3 (vrf lite tp CE-028)
Extractions from printouts:
PE-028#sh mls netflow ip qos
Displaying Netflow entries in Supervisor Earl
DstIP           SrcIP           Prot:SrcPort:DstPort Src i/f         :AdjPtr
Pkts         Bytes         LastSeen   QoS    PoliceCount  Threshold   Leak
Drop  Bucket
224.0.0.2       192.168.16.190  udp :646    :646     Gi2/0/0          0x0
299          18538         16:22:20   0xC0   0            0           0
NO    0
0.0.0.0         0.0.0.0         0   :0      :0       --               0x0
110474       9939421       16:22:25   0xC0   0            0           0
NO    0
mrt-028#sh mls netflow ip
Pkts         Bytes         Age   LastSeen  Attributes
224.0.0.2       192.168.16.190  udp :646    :646      Gi2/0/0          :0x0
3            186           12    09:28:16   Multicast
0.0.0.0         0.0.0.0         0   :0      :0        --               :0x0
250649       20655390      550   09:28:19   L3 – Dynamic
PE-028#sh ip cache flow
MSFC:
IP packet size distribution (4293 total packets):
   1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
   .001 .574 .267 .048 .003 .011 .000 .000 .000 .000 .000 .007 .070 .003 .000
    512  544  576 1024 1536 2048 2560 3072 3584 4096 4608
   .000 .000 .000 .000 .007 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
  1 active, 4095 inactive, 549 added
  26904 ager polls, 0 flow alloc failures
  Active flows timeout in 30 minutes
  Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 33992 bytes
  0 active, 1024 inactive, 0 added, 0 added to flow
  0 alloc failures, 0 force free
  1 chunk, 4 chunks added
  last clearing of statistics never
Protocol         Total    Flows   Packets Bytes  Packets Active(Sec) Idle(Sec)
--------         Flows     /Sec     /Flow  /Pkt     /Sec     /Flow     /Flow
TCP-BGP            101      0.0         1    69      0.0       2.6      15.4
TCP-other          181      0.0        10    62      0.0       5.3      15.1
UDP-NTP             87      0.0         1    76      0.0       0.0      15.4
UDP-other           54      0.0        32   131      0.0     141.8      14.5
ICMP               117      0.0         1    84      0.0       0.0      15.4
IP-other             2      0.0       112   318      0.0     827.3      12.7
Total:             542      0.0         7   105      0.0      19.4      15.2
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP  Pkts
Gi2/0/3       172.19.225.26   Null          224.0.0.5       59 0000 0000    10
PFC:
Displaying Hardware entries in Module 1
 SrcIf            SrcIPaddress          DstIPaddress      Pr       SrcP      DstP      Pkts
 Gi2/0/3          172.18.44.69          172.22.36.8       47       0         0         29
 Gi2/0/3          172.18.45.143         172.22.32.40      tcp      39642     4000      15
 Gi2/0/0          192.168.16.190        224.0.0.2         udp      646       646       180
 --               0.0.0.0               0.0.0.0           0        0         0         426163
 Gi2/0/3          172.18.45.143         172.22.36.40      tcp      48121     4000      2
 Gi2/0/3          172.19.225.26         224.0.0.5         89       0         0         11
 Gi2/0/3          172.18.44.68          172.22.36.7       47       0         0         27
 Gi2/0/3          172.18.45.141         172.22.36.40      tcp      48678     4000      6
 Gi2/0/3          172.18.46.253         172.22.36.36      icmp     0         0         1
CE-028#sh ip cache flow
Displaying software-switched flow entries on the MSFC in Module 5:
IP packet size distribution (4487 total packets):
   .003 .396 .316 .129 .006 .033 .000 .000 .001 .001 .000 .032 .046 .004 .001
   .006 .000 .000 .002 .016 .000 .000 .000 .000 .000 .000
  4 active, 4092 inactive, 351 added
  11059 ager polls, 0 flow alloc failures
TCP-other           31      0.0        93    60      0.0      15.3      10.1
UDP-NTP             43      0.0         1    76      0.0       0.0      15.4
UDP-other          126      0.0         5   301      0.0       1.1      15.5
ICMP               142      0.0         1    84      0.0       0.0      15.4
IP-other             5      0.0       135   270      0.0    1012.4       4.4
Total:             347      0.0        12   129      0.0      16.3      14.8
Gi1/2         172.22.32.55    Local         172.19.248.69   06 FF18 0016    68
Gi1/2         172.22.32.36    Local         172.19.248.69   11 EE79 00A1     1
Gi1/2         172.19.225.25   Null          224.0.0.5       59 0000 0000     3
Gi1/2         172.22.36.36    Local         172.19.248.69   11 E0E3 00A1     9
Displaying hardware-switched flow entries in the DFC Module 1:
 --               0.0.0.0          ---              0.0.0.0         00 0000 0000   405K
 Gi1/2            172.22.32.55     ---              172.19.248.69   06 FF18 0016     0
 Gi1/2            172.19.225.25    ---              224.0.0.5       59 0000 0000    48
 Gi1/2            172.22.32.7      Vl980            172.18.44.68    2F 0000 0000    12
 Gi1/2            172.22.32.8      Vl980            172.18.44.69    2F 0000 0000    10
 Gi1/2            172.22.36.8      Vl980            172.18.44.69    2F 0000 0000    10
 Gi1/2            172.22.32.36     Vl980            172.18.44.35    01 0008 0000     1
 Gi1/2            172.22.36.36     Vl980            172.18.46.22    11 E0E4 00A1    10
 Gi1/2            172.22.36.7      Vl980            172.18.44.68    2F 0000 0000     9
 Gi1/2            172.22.32.36     Vl980            172.18.46.23    11 EE79 00A1     1
 Gi1/2            172.22.32.36     Vl980            172.18.46.6     11 EE79 00A1     1
 Gi1/2            172.22.32.36     Vl980            172.18.44.68    11 EE79 00A1     1
 Gi1/2            172.22.32.36     Vl980            172.18.46.253   11 EE79 00A1     1
0 Replies 0
