NetFlow in Cisco NCS 540
johnlloyd_13
Level 9
Level 9
hi,
i've applied this netflow config in our NCS 540 IOS-XR router which is an MPLS P router.
i checked in our netflow analyzer there's only 2-way/point-to-point traffic/OSPF between this router and another P router also an NCS 540 via the G0/0/0/19 link.
is there an additional command missing to "drill down" the MPLS traffic to see other top talker/IP address?
is sFlow should be configured instead?
flow exporter-map EXPORTER
destination 10.1.1.10
transport udp 2055
source Loopback0
version v9
template data timeout 60
template options timeout 60
options interface-table
options sampler-table
sampler-map SAMPLER
random 1 out-of 500
flow monitor-map MONITOR
record ipv4
exporter EXPORTER
cache entries 1000000
cache timeout active 60
cache timeout inactive 30
cache timeout rate-limit 2000
interface GigabitEthernet0/0/0/19
 flow ipv4 monitor MONITOR sampler SAMPLER ingress
Giuseppe Larosa
Hello @johnlloyd_13 ,
>> record ipv4
if the router is a P node all user traffic travels inside MPLS. You should try to define the flow record to check and collect the MPLS fields.
I don't know if this platform can inspect inside MPLS packets
Hope t help
Giuseppe
jhuffman
I am also trying to setup Netflow on a 540 for exporting to Calix Cloud for their services. The 540 is providing connectivity to the Calix shelf. For some reason the only traffic Calix is reporting they can see is upstream traffic for the end user and no downstream traffic.
flow exporter-map CALIX_EXPORT_MAP
version v9
template timeout 60
transport udp 2058
source Loopback100
destination 54.244.180.84 vrf MGMT
flow monitor-map CALIX_MONITOR_MAP
record ipv4
exporter CALIX_EXPORT_MAP
cache entries 8000
cache timeout inactive 20
sampler-map CALIX_SAMPLE_MAP
random 1 out-of 100
interface Bundle-Ether110
description LL-CRMU-SH1-C1-P4 (BE110)
lacp mode active
lacp system mac beef.0001.0110
lldp
load-interval 30
flow ipv4 monitor CALIX_MONITOR_MAP sampler CALIX_SAMPLE_MAP ingress
interface Bundle-Ether220.1027 l2transport
description CRMU DIA
encapsulation dot1q 1027
rewrite ingress tag pop 1 symmetric
description LL-CRMU-SH2-C1-P3 (BE220)
lacp mode active
lacp system mac beef.0001.0220
lldp
load-interval 30
interface HundredGigE0/0/0/30
description RL-IGP:LL-CRMU-EDGE01
mtu 9208
ipv4 address 10.255.128.119 255.255.255.254
lldp
enable
Anyone run into this issue?
