netflow on 3750
cfajardo1_2
we are on the process of configuring netflow on our cisco devices..one of them is 3750 and i just found a docu with matrix below;
Table 1. NetFlow Recent Cisco Device Support Matrix
Device Supported
Cisco 800, 1700, 2600 Yes
Cisco 1800, 2800, 3800 Yes
Cisco 4500 Yes
Cisco 6500 Yes
Cisco7200, 7300, 7500 Yes
Cisco 7600 Yes
Cisco 10000, 12000, CRS-1 Yes
Cisco 2900, 3500, 3660, 3750 No
this is a 2007 docu. Is there any update on this one specifically on the 3750?
thanks
JORGE RODRIGUEZ
Level 10
Level 10
That is the only document you'll find dated 2007 for Netflow supported platforms. Netflow is not suported on 3750.
If you look in feature navigator ( pick netflow) as feature needed , 3750 does not appears.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Jorge
Jorge Rodriguez
