Netflow on Cisco C6880-X
Peter Valdes
Level 3
Level 3
Has anyone configured Netflow on Cisco C6880-X and registered to Solarwinds?
I'm running c6880x-adventerprisek9-mz.SPA.151-2.SY5 on the two box setup as VSS and would like to monitor traffic on the egress physical interface.
I need to know if this is possible.
Peter
Martin Hruby
Hello Peter
Of course it's possible. I recently configured Flexible NetFlow on a pair of Catalyst 6880-X switches. The configuration is pretty standard, you configure a flow record and flow exporter and then assign both of them to a flow monitor which is then applied to an SVI or physical interface running in L3 mode (i.e. with an IP address). As far as I know it's not possible to run NetFlow on L2 interfaces on this platform. My configuration for your reference:
flow record FlowRecord
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 match interface output
 collect counter bytes
flow exporter FlowExporter
 destination 172.25.99.254 vrf MONITORING
 source Loopback0
 transport udp 2055
flow monitor FlowMonitor
 cache timeout active 300
 cache entries 500000
 record FlowRecord
interface Vlan1711
 ip flow monitor FlowMonitor output
In this configuration, 172.25.99.254 is my Solarwinds NetFlow collector which is reachable over vrf MONITORING and Loopback0 is the management IP address of the switch (also from point of view of Solarwinds NMS). The flow record configuration depends upon your requirements - which fields you want to uniquely match in a flow and what information you want to collect. I enable NetFlow on all SVI interfaces with the ip flow monitor FlowMonitor output command. You might as well use input direction but in this case a lot of flows will be reported with Null interface as outgoing even though it's transit traffic:
81.252.193.70    166.137.11.216            1025           2152  Vl3899                Null                       17        3010
193.253.110.133  81.252.193.70             3386           3386  Vl220                 Null                       17        4889
81.252.193.70    193.253.110.228           1031           2152  Vl3899                Null                       17       37701
Regarding the configuration of Solarwinds NTA you just need to make sure that your Catalyst 6880-X is properly discovered and all interfaces on which you enabled NetFlow are also present. The Solarwinds NetFlow service must be started from the Orion Service Manager. When Solarwinds NTA will start receiving NetFlow exports it will automatically add your Catalyst 6880-X to NetFlow -> NTA Summary page - no special configuration is required.
For more information have a look at: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fnetflow/configuration/15-sy/fnf-15-sy-book.html
Best regards,
Martin
Martin Hruby
Hello Peter
 match ipv4 protocol
 source Loopback0
 transport udp 2055
 record FlowRecord
interface Vlan1711
Best regards,
Martin
Thanks Martin. I will try this out now and let you know of the results.
Peter Valdes
Hi Martin,
One thing you might want to note is that there is a bug whereby the CLI command "cache timeout active 300" under the flow monitor is not actually setting the cache timeout on the linecard (in hardware).
Depending on the traffic passing through the network this could cause the flow data to appear to spike as long lasting flows are not timed out fast enough.
The work around for this that we received from TAC, after having the ticket open for 6 months, was to set the cache timeouts globally using the following commands:
flow platform cache timeout inactive 60
flow platform cache timeout active 60
Further details on the bug can be found here:
https://tools.cisco.com/bugsearch/bug/CSCux22533
Jonathan Miller
